Bleeding the brakes - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-16-2007, 07:09 PM Thread Starter
Bleeding the brakes
Right rear caliper stuck on my 2002 f350, and before I got the chance to get the rotors turned and new pads on I ruined both. I have the new rotor and caliper on but I am having trouble bleeding the sytem. Do I need to pull the abs fuse? Being a one ton I had to pull the floating axle. I am still wondering what the torque spec if any is required on the bearing retainer nut.
Thank you
Brant2289
Brant2289 is offline
post #2 of 7 (permalink) Old 05-16-2007, 07:45 PM
klhansen's Avatar
My Photos: (180)
Re: Bleeding the brakes
I don't think there's a need to do anything with the ABS to bleed the brakes, but the local brake guru FMTRVT (Jack) may come along and see your post. He'll know for sure.
Here's the info on the bearing nut (I'm asuming it's an SRW truck, not a dually, let me know if that's not correct)
Tighten the hub nut, rotating the rear hub occasionally while tightening. The hub nut will ratchet as torque is applied. Tighten to 60 ft lb torque.
Adjust hub nuts as follows:
For new bearings, ratchet back five teeth or notches (1/8 turn) on the hub nut. Five notches must be felt during this operation in order to have performed it correctly.
For used bearings, ratchet back seven teeth or notches (1/6 turn) on the hub nut. Seven notches must be felt during this operation to have performed it correctly.
), AIS,
regulated return,
klhansen is offline
post #3 of 7 (permalink) Old 05-16-2007, 07:46 PM
Clean all dirt from and remove the brake master cylinder filler cap and fill the brake master cylinder reservoir with the specified brake fluid.
Place a box end wrench on the RH rear bleeder screw. Attach a rubber drain tube to the RH rear bleeder screw and submerge the free end of the tube in a container partially filled with clean brake fluid.
Have an assistant pump the brake pedal and then hold firm pressure on the brake pedal.
Loosen the RH rear bleeder screw until a stream of brake fluid comes out. While the assistant maintains pressure on the brake pedal, tighten the RH rear bleeder screw.
Repeat until clear, bubble-free fluid comes out.
Refill the brake master cylinder reservoir as necessary.
Tighten the RH rear bleeder screw.
Repeat Steps 2, 3, 4 and 5 for the LH rear bleeder screw.
Place a box end wrench on the RH front disc brake caliper bleeder screw. Attach a rubber drain tube to the RH front disc brake caliper bleeder screw, and submerge the free end of the tube in a container partially filled with clean brake fluid.
Loosen the RH front disc brake caliper bleeder screw until a stream of brake fluid comes out. While the assistant maintains pressure on the brake pedal, tighten the RH front disc brake caliper bleeder screw.
Tighten the RH front disc brake caliper bleeder screw; refer to Specifications in this section.
Repeat Steps 7, 8, 9 and 10 for the LH front disc brake caliper bleeder screw.
Pressure
NOTE: Master cylinder pressure bleeder adapter tools are available from various manufacturers of pressure bleeding equipment. Follow the instructions of the manufacturer when installing the adapter.
Install the bleeder adapter to the brake master cylinder reservoir, and attach the bleeder tank hose to the fitting on the adapter.
NOTE: Bleed the longest line first. Make sure the bleeder tank contains enough specified brake fluid to complete the bleeding operation.
Place a box end wrench on the RH rear bleeder screw. Attach a rubber drain tube to the RH rear bleeder screw, and submerge the free end of the tube in a container partially filled with clean brake fluid.
Open the valve on the bleeder tank.
Loosen the RH rear bleeder screw. Leave open until clear, bubble-free brake fluid flows, then tighten the RH rear bleeder screw and remove the rubber hose.
Continue bleeding the rear of the system, going in order from the LH rear bleeder screw to the RH front disc brake caliper bleeder screw ending with the LH front disc brake caliper bleeder screw.
Close the bleeder tank valve. Remove the tank hose from the adapter, and remove the adapter.
1999 F-350 - CC/LB, gauges, 40K trans-cooler & external filtration & drain, 203 t-stat mod, Mag-Tech Trans & Diff. cover, AIS filtration, zoodad, HPO x-over, Jody Tipton 40HP tow PCM, Hutch mod and harpooned, Baldwin prepump fuel filter
"Better to be judged by 12, than carried by six!"
nlemerise is offline
post #4 of 7 (permalink) Old 05-16-2007, 08:04 PM Thread Starter
It is a dual rear wheel.
Sorry, I left that out
Thanks [img]/ubbthreads/images/graemlins/confused.gif[/img]
post #5 of 7 (permalink) Old 05-17-2007, 10:35 AM
My Photos: (14)
The only thing that I would add to 8v92tta's quite complete instuctions is, when your assistant pushes the pedal and holds, the pedal will travel farther down than normal. That can be a bad thing for the master cylinder and its seals. Putting a 2 X 4 under the brake pedal to limit the travel is a good idea. It will only take you a few more pumps to complete the job and the chance of crud fouling up the seals in the master cylinder will be gone.
Just my 2 cents.
Jon in American Fork
2002 F-250 Lariat 4X4 Auto PSD CC SRW. Banks 4" Monster Exh, aFe Stage II w/PG 7, TAG II + Hi-Perf Comp Wheel, X-Monitor, SCMT 1705, fuel tank and pre-pump mods, harpooned tank, Zoodad air, always bright overhead, fuel regulator shim, HX oil hose, 2003 Lighted Mirrors, 203* T Stat, Rancho 9000XLs, C-Btr Mirrors, Roll-N-Lock bed cover, Brakesmart and Titan V. 6.0 Tranny Cooler, door seal mod, Powerslot rotors and Hawk pads, HIDs installed in '05 headlights.
JonH is offline
post #6 of 7 (permalink) Old 05-17-2007, 10:42 AM
jarheadatunm's Avatar
If you think you will do this regularly on all your vehicles, I would highly suggest a Motive brake bleeder kit. Fill it up, attach to the reservoir, pump up to pressure, start bleeding by yourself! It is one of the best tools I have bought. The self-closing bleeder valves are pretty good setup from what I have heard also, but I have never used them.
2000 F250 PSD, 4x4, Red
Banks 4" Exhaust, Big-head Wastegate, DP tuner Chip (80econ, 60 tow, 100 race...), AFE Stage II, Turbonetics Torque-Master .84 turbo, Spearco 6.0 retro-IC, EBPV removed, Ram-air Mod, BWD bellowed up-pipes, Ford HD 4R100 Transmission. Mag-Hytec trans and diff covers, full gauges.
AE if you need a scan...just PM me.
jarheadatunm is offline
post #7 of 7 (permalink) Old 05-17-2007, 01:05 PM
SpeedBleeders [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Drivetrain:7.3L PSD, 4WD, Auto, 3:73 LS
Fuel Mods:Hutch Pre-Pump Mod w/Purolator F50154, 55-gallon AeroTank midship replacement tank
Chassis Mods:ART frozen slotted rotors, PF Carbon Metallic Pads, Stainless SpeedBleeders, Bilstein 2818/2819, BFG MT 285/75-R16
Fluids and Filters:Mobil Delvac 1 w/M1-601 synthetic element filter, Mobil 1 ATF w/Magnafine Filter, ATE Super Blue brake fluid
Accessories:Viper 791xv alarm and remote start, Ford AIC w/ITP relocation bracket, AIS, Fumoto Valve, 24" Bosch Micro-Edge Excel blades, Dash Designs Cover, Xtreme Catch-All matts, 84" folding Dog ramp, SnugTop Extra Vision shell, Wet Okole seat covers
NRTS is offline
