Block heater eletric usage - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 01-21-2006, 06:05 PM Thread Starter
How much electric does the block heater use. my electric bill was high and I haven't used any thing that uses a lot of electric for a while but my use age is still way up. I know heating elements use a lot of power. but this seams rediculous
-'01 f250 reg cab long bed 4x4 auto 7.3, harvest gold, isspro ev guages, ats/ts 6 pos. chip, limo glass.
-1979 CJ-7 304 auto green and bed liner
-1966 Pontiac Tempest custom gto clone project car
mvmudslinger is offline
post #2 of 15 (permalink) Old 01-21-2006, 06:18 PM
Re: Block heater eletric usage
I'm not sure but isn't the block heater a 1500W element? That would be about 10A of electricity. Keep it plugged in overnight (repeatedly) and I can see where your bill would feel it.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
post #3 of 15 (permalink) Old 01-21-2006, 06:25 PM Thread Starter
I'll probably get a timer then
post #4 of 15 (permalink) Old 01-21-2006, 06:32 PM
If I remember right, its 1000 W and aprox. 9 AMPS. Leaving it plugged in for 10 Hrs every day could raise your electric bill 20 to $30 every month, depending on where you live. Use a timer set for 3 Hrs prior to planned useage. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
post #5 of 15 (permalink) Old 01-21-2006, 07:09 PM
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
I've started mine at any temperature above 5 or 10 degrees F. Cycled the key for a lot of extra glowplug, and it shakes, smokes, and stinks for 5 minutes. But it always starts.
I don't have a regular schedule so heating my block every cold night would be a waste.
NY is a lot warmer than it used to be, but I can't imagine too many Kentucky nights below zero. Save your money and don't bother with the block heater.
-steve
SteveRacer is offline
post #6 of 15 (permalink) Old 01-21-2006, 07:38 PM Thread Starter
I'll keep it in mind, but i like not having to scrape the windshield in the morning.
post #7 of 15 (permalink) Old 01-21-2006, 09:24 PM
Consider an oil heater. I bought one from WOLVERINE oil heaters.com, they are manely used up in Canada and Alaska but hey our PS are oil sensative, part of the fuel system. Since I started using mine without the block heater my truck starts even better on the 20-30 degree AM's and its only 250 watts, not much elec. usage with better results than a block heater.
http://www.wolverineheater.com/products.shtml
2000 F-450,Crew Cab,4x4,Flatbed,4.88 diffs
Sumitomo 245/70R19.5--Centramatic balancers--AIS with Fender Sleeve--Chrome Simulators/Dieselsite--Coolant Filter/Dieselsite--Trans Filter/Dieselsite-- A-C valve/Dieselsite --Oil Gaurd bypass filter--Fumoto valve/Dieselsite--SkyJacker Steering Stabilizer-- 4 Gauge A Piller Pod(pyro,boost,trans,volt)--Muffler delete--AIH delete--Gas Magnum shocks--ITP HX mod--Wolverine Engine Oil Heater--GOLD coolant---CCV mod---ITP Pre pump/tank Kit---WIX prepump Filter/Separator---FIA grill cover---Zoodad Mod---REDHEAD steering box---ROTELLA 5-40 Synthetic---MOBIL 1 syn PS fluid---Magnefine PS filter---STACK single/chrome/5"---
ON THE FLATBED>-- Miller Trailblazer 302-- Suitcase MIG 12vs x-treme-- 2 60" boxes/ 2 36" boxes-- and all the necessities
SKEET298 is offline
post #8 of 15 (permalink) Old 01-21-2006, 09:36 PM
I use a timer from McMaster-Carr.
Part Number 7001K24
It was only $24.38 plus shipping.
Works great and easy to program!
2001 F350 Lariat CC DRW 4X2 LWB PSD
1997 F350 XLT CC SRW 4X4 LWB PSD
<span style="color: red">Give the gift of life.
Become an organ donor!
</span>
BGas is offline
post #9 of 15 (permalink) Old 01-21-2006, 09:49 PM
I use a timer also, WALMART- 9.99$. It handels up to 15 amp's which our block heaters are only supposed to be 8.6 amp's at 1000 watts. I have a two way connecter to hook up both the block heater and the oil heater if I feel like I need the extra heat. The oil heater does a wonderful job of making my truck fire off without any spit,stuuter,fumble,chug,and what not.. It is GREAT.
SKEET in Texas [img]/ubbthreads/images/graemlins/grin.gif[/img]
ON THE FLATBED&gt;-- Miller Trailblazer 302-- Suitcase MIG 12vs x-treme-- 2 60" boxes/ 2 36" boxes-- and all the necessities
SKEET298 is offline
post #10 of 15 (permalink) Old 01-21-2006, 10:05 PM
Sounds like you are well-prepared to deal with the frozen tundra of Texas. [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
post #11 of 15 (permalink) Old 01-21-2006, 10:21 PM
Stink_Pickle's Avatar
My Photos: (12)
I hope your running the winter blend down there. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Rich
KC Stage 3, Full Force 190/75, UCF Ported O-Ringed Heads, ARP Studs, Sinister Up Pipes, ODAWG Ported Intake, Ultra FICM Atlas 40, IPR EGR Delete, Driven RR Kit w/Spring, Fass Titanium 200, BD Exhaust Manifolds, Mishimoto Intercooler and Radiator, BPD Water Pump, OUO Traction Bars, MBRP 4 TB SS Duals, No Limit Cold Air, Sinister Coolant Bypass w/Rotella ELC, Sinister Oil Bypass w/Rotella T6 Syn, Edge CTS w/EGT & FP, Sinister Charge Pipes and Intake Elbow, SCT X4 , DC Power 190 AMP w/1GA Cables, Mishimoto Baffled Catch Can, Hellwig Rear Sway, AMP Steps, 275/65/20, 08 Tow Mirrors, Ram Air Hood, ARB Air Lockers, Warren Diesel Comp Plus Trans, Beans Sump, BD Deep Trans Pan
CC Lariat, SB 3.55 E-Locker, Navigation, Dual Alt, FX4 20" BMF Novakane, Toyo MT's, Air Bags, Rear Sway Bar, Amp Steps, Bilstein 5100's
Stink_Pickle is offline
post #12 of 15 (permalink) Old 01-21-2006, 10:41 PM
yeah, you need straight up #1
mikeym is offline
post #13 of 15 (permalink) Old 01-22-2006, 01:52 AM
It's not cold until you have to "plug in" your batteries. I have 4 plugs coming out of my grill. OE Block heater, 2 60W battery heaters and a 150W oil pan heater. The battery pads are plugged in 24/7.
2013 F350 CC Lariat 4x4 6.7L
2003 F250 SC Lariat FX4 6L sold
AK6LPSD is offline
post #14 of 15 (permalink) Old 01-22-2006, 09:21 AM
SmokeyWren's Avatar
My Photos: (45)
1,000 watts, or one KWH every hour. The cost of electricity is about 10 to 15 cents per KWH, so it costs you 10 to 15 cents every hour you have it plugged in.
So 3 hours on a timer will cost you 30 to 45 cents. But 10 hours overnight will cost you $1.00 to $1.50 per night. That difference in electricity costs will pay for a timer real soon now. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
For you folks in the Socialist Republic of Canada, it probably costs even more - unless the socialist government is subsidizing the cost of electricity. [img]/ubbthreads/images/graemlins/eek.gif[/img]
SmokeyWren is offline
post #15 of 15 (permalink) Old 01-22-2006, 10:56 AM
Cool_Canuck's Avatar
My Photos: (12)
[/ QUOTE ]LOL Larry; No it is not the socialist government subsidizing our energy rates. It is youz guys. [img]/ubbthreads/images/graemlins/grin.gif[/img] And we do thank you for that.
You see, in one of our capitalist moments [img]/ubbthreads/images/graemlins/shocked.gif[/img], we built several clean hydro electric generating dams. We produce far more energy than we can use and export the surplus to youz guys. Well not to Texas youz guys but the midwest and eastern seaboard types. Guess you might say we are the light of your life. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
BTW - We pay less than .06 kwh.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/
; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED;
Cool_Canuck is offline
