Blower Motor Resistor Location? - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 10-30-2007, 09:40 PM Thread Starter
Hey all, my blower motor only runs on high, so I picked up a Blower motor resistor from the stealership and now I have no idea where it is located. I have looked around the blower motor itself and could not find anything, looked around the fuse distribution area, behind the glove bow, but I just cannot figure out where it is.
stangs400 is offline
post #2 of 18 (permalink) Old 10-30-2007, 09:42 PM
weasel79's Avatar
Re: Blower Motor Resistor Location?
Year, make, model, etc. of truck would help.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe,
weasel79 is offline
post #3 of 18 (permalink) Old 10-30-2007, 09:44 PM Thread Starter
Apologies! 2006 F350 6.0l crew cab.
post #4 of 18 (permalink) Old 10-30-2007, 11:29 PM Thread Starter
nobody? really looking to get this fixed tonight, been searching for hours!
post #5 of 18 (permalink) Old 10-30-2007, 11:39 PM
whitjo's Avatar
Not sure about the 06 but on my service info on a 99 it says it's located on the evaporator core housing underneath the hood.
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
whitjo is offline
post #6 of 18 (permalink) Old 10-30-2007, 11:48 PM Thread Starter
sorry, but I dont have any clue where that is either? Next to the blower motor itself?
post #7 of 18 (permalink) Old 10-30-2007, 11:52 PM
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: stangs400</div><div class="ubbcode-body">sorry, but I dont have any clue where that is either? Next to the blower motor itself? </div></div>
look in the engine compartment, passenger side where the AC components are, should be there somewhere, again my info is for a 99 but it may be the same for yours?
whitjo is offline
post #8 of 18 (permalink) Old 10-31-2007, 01:00 AM Thread Starter
still cant find the dang thing!
post #9 of 18 (permalink) Old 10-31-2007, 01:09 AM
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: stangs400</div><div class="ubbcode-body">still cant find the dang thing! </div></div>
I'll look at mine but it will be tomorrow, if you haven't found it yet. it's midnight here and I'm headed for bed!
whitjo is offline
post #10 of 18 (permalink) Old 10-31-2007, 02:18 AM
My Photos: (21)
Refer to this picture.
O
02/03 built
6L, DRW,
, 4" DPPI Exhaust, UltraLites on the
and
, Firestone Bags & Compressor,
, 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0,
, XM Commander.
ozhoo is offline
post #11 of 18 (permalink) Old 10-31-2007, 09:08 AM Thread Starter
See, I have that resistor as a replacement, but what is in that area is something completely different! I took it out and it like has heat sinks on the back, and actually plugs into the bottom of the module?
post #12 of 18 (permalink) Old 10-31-2007, 01:37 PM
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: stangs400</div><div class="ubbcode-body">See, I have that resistor as a replacement, but what is in that area is something completely different! I took it out and it like has heat sinks on the back, and actually plugs into the bottom of the module? </div></div>
Then probably there has been a change in design since 99
Mine looks exactly like the picture the other poster put up.
whitjo is offline
post #13 of 18 (permalink) Old 11-02-2007, 04:31 AM
You must have the ATC-(automatic temp. control) A/C system(has digital readout& all push-buttons). If what your pulling out of your existing evaporator case has a heatsink, that indicates that it's the auto. system.The manual system uses old metal coils and no mini-electronics.
I'm also experiencing this same problem with my '05 King Ranch-blows on HI only, and haven't had time to look into the source of the problem.
Let us know what happens. DB
2005 Dark Copper King Ranch CC 4x4 6.0 F250
MAC cold air
'08 eight-spoke 20's
Pop-up flip ball GN hitch
Fiveohgod is offline
post #14 of 18 (permalink) Old 11-02-2007, 11:59 AM
I replaced mine awhile back and what a pain in the butt. The extended warranty would have covered it but the cost of the decutable was more than the part was. Good luck with it you really need to push the air conditioning line out of the way, the one off of the dryer.
refuse2
2005 F-250 Dark Toreador Red, Lariat Lux. package, 6.0 PSD, TNN0 Pcm code, Torqueshift auto trans, 4x4, ESOF, tow command, Fumoto valve, Magnaflow 4" turbo back and no kitty, Sirius Satellite radio, Retrax bed cover, Harpoon mod, ccv mod, GOS headlight harness, Fog Light High Beam Mod, Heated mirrors upfitter #1, AIC upfitter #4, Wix Powertrap with no mass airflow sensor, Direct Injection Performance Coolant filter, Oil Guard by-pass, and Schaeffers 5w40.
refuse2 is offline
post #15 of 18 (permalink) Old 10-17-2013, 01:13 PM
Did you get this solved? I also have a 2006 with Automatic Temp Control. Took it to my guy and we switched the resistor out with his (also a 2006...). Voila, it worked. So I'm off to get a new resistor and install myself. It is a bit tricky to get the bottom screw out of the resistor. You need to remove the 3 screws holding the AC component in place and move it about 1/4". I can take pics if you still need location etc. The pics above in this are of a truck with Manual Temp Control.
2006 F-350 King Ranch 6.0; Banks Ram-Air; EGR Delete; 4" exhaust; Banks 6-Gun (non funct after EGR Delete); 20" Wheels.
RedStagg is offline
