Brake Fluid Flush? What type? - Diesel Forum - TheDieselStop.com
Old 12-18-2007, 10:45 PM   #1 (permalink)
I'm currently at 85k miles, and I think its time to flush the brake fluid on my 2004 F-350. I'm assuming that I can just crack open the rear bleeder, and pump the old fluid through the lines, and add new fluid to the resivoir. What type of fluid is reccomended? Regular old DOT 3? DOT 4? Any special type required? Thanks!!
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline   Reply With Quote
Old 12-18-2007, 11:00 PM   #2 (permalink)
Lightningfast01's Avatar
Re: Brake Fluid Flush? What type?
I use Valvoline syn power. It is cheap, synthetic, easy to find and has good temps. ATE amber is good also but harder to find.
http://www.valvoline.com/pages/produ...asp?product=51
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline   Reply With Quote
Old 12-18-2007, 11:03 PM   #3 (permalink)
You cannot mix synthetic brake fluid with DOT 3 or 4 - it will gel up. If that gel gets into the calipers, it will clog up. I made this mistake in my race car and had no brakes by the end of that night!
New truck
2008 F250 6.4L. Banks Six Gun with IQ, Banks CAI, Banks Monster filter back exhaust, AMP steps, 4" ProComp lift with 35s
Old truck
2004 F250 6.0, 4" T-back MBRP, AFE Stage II/PG7, CFM+ Largemouth, Snow Stage II Meth injection, Pyro, Trans, Boost pillar mount, SCT running Extreme Street, ITP reg return, AirDog, Oilguard bypass, CCV mod, Diesel Site coolant filter, harpooned, 08 Diff cover, Daystar levelling kit, Viair onboard air with Siege train horns, heated mirror switch, Hella 500 Driving and Fog lights behind Billet grille, back-up lights, Kenwood 7019 in-dash DVD, Alpine S in the doors, 2 10" JL subs with Alpine amp.
ryano2121 is offline   Reply With Quote
Old 12-18-2007, 11:06 PM   #4 (permalink)
You are a grade A dip**** pour it right in. You are speaking of silicone fluid. Read my link compatible with conventional fluids.
Old 12-19-2007, 12:07 AM   #5 (permalink)
Wow. You got me. My mistake. Way to go man. Definitely shined there. You da man.
New truck
Old truck
Old 12-19-2007, 12:20 AM   #6 (permalink)
We're all keyboard engineers and race car mechanics right. It is just fun when you catch one talking out their arse. It is only for comical effect I still love you. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Old 12-19-2007, 12:31 AM   #7 (permalink)
You know, I started racing a Legend last year. I started knowing absolutely nothing - couldn't even change the oil. I ended up the year qualifying 2nd in the nation in the semi-pro division. I was moved up to pro for the upcoming year. I rebuilt my current car and built another one as well. I learned a huge amount on a forum for Legend cars, from people that knew more than me.
I started working on my truck after reading this forum for a long time. Now I have done quite a bit of work and can do a lot more than I ever would have guessed I could. Again, that is thanks to all the great people on here willing to help someone out who knows less than them. I ask a lot of questions - that is how I am learning. If I make a mistake, please correct me. But there really is no need to insult me.
Thanks for pointing out my mistake though. I do appreciate it.
New truck
Old truck
Old 12-19-2007, 12:44 AM   #8 (permalink)
Castrol GT LMA (low moisture affinity) dot4
FJK1 is offline   Reply With Quote
Old 12-19-2007, 07:53 AM   #9 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: NCfarmboy</div><div class="ubbcode-body"> I'm currently at 85k miles, and I think its time to flush the brake fluid on my 2004 F-350. I'm assuming that I can just crack open the rear bleeder, and pump the old fluid through the lines, and add new fluid to the resivoir. What type of fluid is reccomended? Regular old DOT 3? DOT 4? Any special type required? Thanks!! </div></div>I highly recommend ATE Super Blue Racing Fluid The color change of the fluid makes it very easy to determine when the the new fluid has completely replaced the old fluid. When bleeding the calipers, the fluid will go from grungy black to brown to amber to green to blue and then you are done with that caliper. It is best to remove all the old fluid you can from the master cylinder/reservoir before changing. I've got blue in now and will change to their amber formulation before next year's towing season.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline   Reply With Quote
Old 12-19-2007, 08:39 AM   #10 (permalink)
My Photos: (5)
Yep, exactly with haulin said and if you don't have a powerbleeder, I recommend: http://www.motiveproducts.com/index.html
I found this to be a great help. I no longer need to get a family member out there to pump brakes.
When I bought the ate, there was a price break and I bought the blue and the amber. I now have it in all our cars and just swap back and forth colors when needed.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 104,500 miles.
clydesdale is offline   Reply With Quote
Old 12-19-2007, 08:40 AM   #11 (permalink)
Pappy19's Avatar
My Photos: (6)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: haul_n_horses2</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: NCfarmboy</div><div class="ubbcode-body"> I'm currently at 85k miles, and I think its time to flush the brake fluid on my 2004 F-350. I'm assuming that I can just crack open the rear bleeder, and pump the old fluid through the lines, and add new fluid to the resivoir. What type of fluid is reccomended? Regular old DOT 3? DOT 4? Any special type required? Thanks!! </div></div>I highly recommend ATE Super Blue Racing Fluid The color change of the fluid makes it very easy to determine when the the new fluid has completely replaced the old fluid. When bleeding the calipers, the fluid will go from grungy black to brown to amber to green to blue and then you are done with that caliper. It is best to remove all the old fluid you can from the master cylinder/reservoir before changing. I've got blue in now and will change to their amber formulation before next year's towing season. </div></div>
I highly recommend this product as well.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline   Reply With Quote
Old 12-19-2007, 09:23 AM   #12 (permalink)
The ATE Fluid looks like the ticket. How much do I need? 1 bottle? 2? Thanks!
Old 12-19-2007, 09:40 AM   #13 (permalink)
My Photos: (17)
One would be just enough but if you need more thorough flushing two would be more than enough.
Old 12-19-2007, 06:40 PM   #14 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: clydesdale</div><div class="ubbcode-body">Yep, exactly with haulin said and if you don't have a powerbleeder, I recommend: http://www.motiveproducts.com/index.html
When I bought the ate, there was a price break and I bought the blue and the amber. I now have it in all our cars and just swap back and forth colors when needed. </div></div>
Great product those Motive pressure bleeders. I change mine every second year. No over pumping the main cylinder. Almost to easy. I wouldn't worry about that color change. I just replace the master reservoir with new fluid, set the pressure bleeder up and pump a pint of so out of each wheel cylinder. The volume alone will get any old fluid out, not that much in the lines anyway.
2002 F250 7.3L PSD, bought new now at 202K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline   Reply With Quote
Old 12-20-2007, 01:18 AM   #15 (permalink)
I have used the blue a few times and it was kind of nasty looking to people that didn't know what it was. So I stay with amber or clear fluids so my friends think I maintain a good brake system. That is what counts for me, lol!
Valvoline Synpower is a great choice for price an availability. It has better temps than GT LMA and about the same as ATE I use to have it all memorized.. I ran Motul RBF600 in my race brakes.
http://forums.nasioc.com/forums/arch.../t-507293.html
