Brake switch question - Diesel Forum - TheDieselStop.com
Old 11-15-2008, 07:01 PM   #1 (permalink)
I put a new brake pedal switch in my 04 f-250, and after installing, it won't go into gear. Any suggestions?
woody04 is offline
Old 11-15-2008, 07:38 PM   #2 (permalink)
Banned
The first question HAS to be "why did you replace the brake switch?".
GrampyJim is offline
Old 11-17-2008, 02:03 AM   #3 (permalink)
Brake Switch
I replaced the switch because I was given a code to do so. The reader said "Brake Switch out of range". The reason I had it checked was because of a rough idle, and it was dying on me when I applied the brakes. After putting on the new switch, the problems went away. But, I had the issue with it not going into gear after installing. The part I used was a BWD brand switch. I am waiting on Monday to get an OEM Ford switch to see if there is a difference.
woody04 is offline
Old 12-07-2008, 12:17 AM   #4 (permalink)
All good now. I changed to an OEM switch, and the gear shift now works. After putting this switch on, I found out that I had a bit more expensive problem. The problem with the idle turned into a bad surge. Turns out, it was my ICP Sensor all along. After around $500 or so, the truck is back to normal.
woody04 is offline
