brakes (abs light) - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-04-2006, 08:44 AM Thread Starter
ercbigblock's Avatar
brakes (abs light)
does anybody know why my abs light comes on and stays on .I have a 99 powerstroke with a 7.3 6 speed manual trans. I have checked codes and their is no code stored. I only have a rear diff sensor . Any help would be nice. Thanks Russell [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2001 crewcab 4x4 7.3 373 gears 4inch exhaust, boost, pyro, trans gauges ,chip
ercbigblock is offline
post #2 of 7 (permalink) Old 10-04-2006, 10:52 AM
My Photos: (61)
Re: brakes (abs light)
I would post in the 99 and up general forum, this is not the place for this question.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
post #3 of 7 (permalink) Old 10-05-2006, 05:16 PM
Hope this helps,mine comes on sometimes in the winter after running thru a deep puddle of water(couldn't stop- traffic had to do it)at a good clip,light was lit up for a few hours one time, a day or so others,before I could get it for service went out by itself at start-up.
I assume it dryed up and reset when the key was switched off/on.
99 f250 PSD stock as possible ok just a fumoto,and bilsteins
honeeagle is offline
post #4 of 7 (permalink) Old 10-05-2006, 06:42 PM
My abs light would come on periodically, and on a panic stop, allow one side of the brakes to grab while the other side wouldn't. I thought I was going nuts, because it didn't do it every time. Took it to my brake shop (I was prepared to just have them do a complete 4-wheel brake job if it meant not having the problem). I have 4-wheeel ABS, so they crawled up under the front end and snugged up bolts that hold the abs sensor in place on each front wheel. They did the same thing on the rear (only one sensor on the rear). That was in February, and i haven't had a problem since. So, maybe just snugging up the bolt that holds the abs in place, and making sure the plug is firmly seated, is what you need to do. Hope this helps.
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, BAK RollX bed cover, Bed mat, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, undercoated, 156k somewhat trouble-free miles (so far), Edge Evolution (60 HP setting), Pioneer DVD/CD/iPod/XM satellite, backup camera
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2) and tension pullies, all 4 power lock actuators, water pump, air conditioning lines and compressor, battery cables, replaced the leather oem seat covers with very good leather replacements (found a great place and price from a place in Dallas that custom makes them)
2016 Subaru Outback (Wife's commuter car)
2016 Starcraft Autumn Ridge 29ft TT
short_stuff is offline
post #5 of 7 (permalink) Old 10-07-2006, 01:39 AM
Banned
What are you using for a scan tool? Not all scanners can access proprietary modules.....
GrampyJim is offline
post #6 of 7 (permalink) Old 10-08-2006, 09:44 PM
JimTJr's Avatar
My Photos: (20)
Dave / Believer45
[/ QUOTE ] Dave?? THis IS that forum! (Unless it got moved and I didnt know that,,,,lol)
ERC,,,, I would replace that VSS sensor on the rear diff. It is not expensive and really on a 99 that the MOST Common thing that can cause the ABS light to come on,,,(I really dont know what else would,, unless it has a GEM module...)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #7 of 7 (permalink) Old 10-14-2006, 10:02 AM
How about the lamp in the passenger side deactivation switch? Just had mine replaced by the dealer (to the tune of $375! ). The ABS warning light on the dash came on and stayed on continually.
Arnie
2011 F-350 SD 2WD Automatic SuperCab Lariat 6.7 L Diesel Dually
2004 Mobile Suites 36TK3 fiver #1201
2004.25 F-450 SD 2WD PSD Automatic SuperCab Lariat with Fontaine Classic Traveler RV bed Traded
wandrr is offline
