Brakes went out Need help...ASAP please - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 09-14-2008, 08:15 PM Thread Starter
Hi everyone.
when i came out from church tonight an got in my truck the brakes went to the floor. i ran around in it all day an it seemed ok then.
i tried to pump them up but did not help. i only live a few blocks from the church so i limped it home the pedal go's allthe way to the floor. they did stop me but i did not get over 20 MPH.
the brake fluid container is little over half full.
i'm just not sure where to start on this project. should i try bleeding them first? i know if anyone had the answer this would be the place to get it.
Thanks in advance.
Steve
2002 F-250 4X4 Off Road CC Lariat SB 7.3 PSD White over Arizona Beige .
AR NITRO Wheels,305 70R 16 Good Year Wrangler
SuperChips Max Micro Tuner 1705 and line-X.
A-piller isspro Gages Pyro,Boost,Trans.
AFE Stage II, P-G 7 ,
4" MBRP Turbo back Exhuast
** 2" Leveling kit is next on my list.
Steve67 is offline
post #2 of 11 (permalink) Old 09-14-2008, 08:29 PM
overfly's Avatar
My Photos: (16)
I would start by checking the brake lines and calipers for a leak. If they went out suddenly the leak should be pretty obvious. Could be the master cylinder but I don't think that is too common and usually there would be signs of a bad seal long before it went out completely. Ever been stopped and feel the pedal slowly sinking to the floor?
2006
- Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
post #3 of 11 (permalink) Old 09-14-2008, 09:36 PM Thread Starter
Thanksfor the reply;
not that i can think of.
it never did have alot of pedal. i will get under it in the morning and look for leaks if i dont see any i guess i will blead them. an see what that does.
Steve67 is offline
post #4 of 11 (permalink) Old 09-15-2008, 07:59 AM
dlblazer's Avatar
Sounds like a master cylinder to me.
Current truck: 2002 PSD 4x4, CC, XLT, F350 dually, 4.10 gears. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO gauges (boost, EGT, trans, fuel pressure), PHP Hydra, full EBPV delete (pedestal & outlet), CNC Fab HP & HPX lines, Riff Raff FRX, Riff Raff IC boots, CCV mod w/catchcan, Reese Titan, AIS, ITP pre-pump filter kit, in-tank mods, Redhead steering box.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, CCV mod, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, ITP pre-pump filter kit.
dlblazer is offline
post #5 of 11 (permalink) Old 09-15-2008, 08:40 AM Thread Starter
i know last night i was standing outside the truck an was pumping the pedal with my hand and it seem like it was not comeing back as fast as it should. going to look at it after this cup of coffee. what does a master cylinder cost?
Steve67 is offline
post #6 of 11 (permalink) Old 09-15-2008, 09:36 AM Thread Starter
WELLLLLLLLL,
The main line that runs to the back has a rusted area with a nice hole in it
about 6" from where the metal and rubber line meet. altho thats a bummer that will me cheeper than a master cylinder.
THE FIX:
where the frame swoops down in front of the fule tank the line is most accessable. i am going to cut the line there an use a compression fitting an replace from there back. if there is any reason i should not do it like this please let me know.
Steve67 is offline
post #7 of 11 (permalink) Old 09-15-2008, 08:15 PM Thread Starter
Ok it's fixed.
and it was easy as pie. i cound not beleave how easy it went. only took about 30 minutes .
i was so happy i changed the oil , put on new wiper blades and bought a new drop hitch an slapped it in.
Then took the pups out to chase a bunny .....and they POUNDED one for 3 circles . ran another one round it was a small one and had a line on another one but it got dark on me. and to top it all off the ex. called and is divorceing the guy she left me for .
MAN what a day. life is gooood
take care all and god bless.
Steve
Steve67 is offline
post #8 of 11 (permalink) Old 09-16-2008, 09:29 AM
You should not use a compression fitting for brakes!
You should use a flaring tool & proper fittings.
jade97 is offline
post #9 of 11 (permalink) Old 09-16-2008, 08:18 PM Thread Starter
i see your point thanks.
Steve67 is offline
post #10 of 11 (permalink) Old 09-16-2008, 09:45 PM
After I had one brake line rust through, it didn't take long before another went. When I look around under there, I saw just how rusted they were. I just went ahead and replaced them all! The first one went out while I was pulling my fifth wheel trailer home from a trip to the mountains in North Georgia. I was lucky the the line went in the flat lands of Central Indiana.
Big Diesel - 2010 F250 XLT SuperCab Long Bed 4x2.
Little Diesel - '02 VW Jetta TDI Wagon 5 spd manual.
flyman is offline
post #11 of 11 (permalink) Old 09-18-2008, 09:02 PM
dlblazer's Avatar
I have used compression fittings for a temp brake line fix. I'm pretty sure that they are specifically not "legal" to use for a brake line fix. The better alternative is to cut the line at a point with good metal, slip a fitting over the line and flare it. Then add another line by attaching it via fittings.
Its more work, but safer for you, your family, and me.
dlblazer is offline
