1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Need some help folks. when going over rough ground or hitting a bump on pavement I'm getting a bump in the floorboard under my feet. I've noticed the "torsion bar", I think which runs from the front axle back to two braces that run up to the floorboard have a rubber grommet where they are bolted together. These rubber grommets on my truck are both worn out. Is this what is causing the bumping and if so how do I replace them??
Early 99 (4/98) F250 X-CAB 4x4,automatic tranny,DP Tuner 40HP tow PCM,Sonnax tranny kit,C-Betr mirrors, XM radio, Cobra CB,gooseneck hitch. 315,000 miles and counting!!!!!
My early 99 at work has just started doing the same thing lately.
I suspect it is the swaybar end links as the rubber bushings are looking pretty bad. I will be tackling that any day now.
__________________ "Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, 4x4 A Few Mods To Make It Better than Stock
well the first time mine did that wonderful noise i replaced the sway bar bushings 10 bucks a piece at the stealership.....that was about 10000 ago...well its doing it again so went back bought more and that didnt fix it??? so im thinking endlink bushings also
2001 excursion limited black w tan
2008 center console
ts 7 switch chip
4" turbo back
7"superlift
20" ultra goliath 20x9
nitto terra grapplers 355/60/20
viper 7601 alarm remote start w smart start
SOLD....... 2008 xlt crew 6.4 4x4 silver 17x9 kmc spy wheels black 315/70/17 bfg tko
clearshiled paint protection
3m tint 20% fronts 5% over factory rear
uriah products rapid hitch
pionner avicz2 ipod control xm navtraffic
2 pioneer tssw1241d subs custom box around rear seat belt
rockford bd100 amp
edge insight
hid headlights (foglights next)
putco smoked led mirror lights
stay tuned!!more to come soon
87 mustang notchback new 391 cu in stroker dart block jegs/kasse heads turbos or big nos undecided??
I'm in the same situation. I've replaced my end links, sway bar bushings and my ball joints are 18k miles old...and I still have the thump. I'll be pulling the sway bar off and driving it for a day and hopefully that will eliminate all of its related parts.
2002 Super Duty CC Lariat 4x4 4.5" Donahoe Racing lift
thats what i was thinking today...im going to do that this weekend and see what happens
2008 center console
ts 7 switch chip
4" turbo back
7"superlift
rockford bd100 amp
edge insight
Mine has been clunking for a while now (front). The main sway bar mount bushings are worn. I bought new ones this morning at the dealer and total came to $28.
Will replace them when the weather gets warm (June).
Am I supposed to use grease in the new bushings?
"Coming together is a beginning; keeping together is progress; working together is success." -Henry Ford-
2008 center console
ts 7 switch chip
4" turbo back
7"superlift
rockford bd100 amp
edge insight
I would bet the noise is coming from the stabilizer bar end links. For my 2002 they cost $100.oo and come as complete units..not just bushings. Make sure you torque them per specs and apply locktite if you want . JOHN
2002 Ford F350 CC SRW 7.3 auto with Banks Stinger Plus, 3 gauge pillar with EGT, Boost, Trans Temp. AFE Stage 1, Diamondback Cover(ATV sideloading and rearloading packages}. 3512 Keystone Raptor 5th wheel ToyHauler. Tru-Cool Transmission Cooler. Dick Cepek Radial FC-II tires. Frozen rotors with pads.
