Bumping Noise In Floorboard ?????? - Page 2 - Diesel Forum - TheDieselStop.com
Old 02-22-2006, 08:27 PM   #16 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: Bumping Noise In Floorboard ??????
Any idea what the torque values are for the end links and the bushing bracket at the sway bar?
[/ QUOTE ]"The torque spec for the bushing is 35 ft/lb and the link nuts are 85ft/lbs. I got the info off the ford dealer website fyi." per this thread.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 02-22-2006, 08:42 PM   #17 (permalink)
"Awesome"
Thanks for a straight and simple answer
Bushwakd
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, 4x4
A Few Mods To Make It Better than Stock
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline
Old 02-22-2006, 10:35 PM   #18 (permalink)
Another thing to check is ball joint play. A friend of mine thought his sway bar end links were on their way out on his '04, but when he went to check them, found that both ball joints were done.
This may or may not be your issue, but it's worth checking.
'02 F250 4x4, 7.3L PSD. Extended cab, Banks 4" Stinger exhaust.
nichols is offline
Old 02-23-2006, 04:52 AM   #19 (permalink)
dezertchase's Avatar
when mine made that noise i took it to the dealer. that had fixed the bumper from a fenderbender. When they where putting it back togather they called and said my frame was bent. I talked to the old timer in the body shop. said it was probably from the factory that way ( the frame ) they put it on the frame machine and straightened it out. well about 500 mi later i got the noise in the floorboard. the guy in the body shop check everything and said no broblem. then i went over to the oldtimer that fixed the truck showed hime where the noise felt like it was comming from. under right foot driverside only. he then put a breaker bar on the body bolt under my right foot and got 3 complete turns on it. he said that he torched to spec and this had never happened before. so he went to the passengerside and got2.5 turns on that one. noise has not returned in 10,000 mi and i use the truck to chase a trophy truck in score desertracing. just my thoughts.
2005 f250 fx4 charcoal grey sport 2.5"leveling kt 35x18 nito graplers on 18" mb preditors, xm satilite, CDT components in the doors, 2 planet audio 10" behind the seat and 2 planet audio amps
no performance mods no problems
dezertchase is offline
Old 02-23-2006, 12:21 PM   #20 (permalink)
LGW
I had the bumping sound under the floor board too. Changed ball joints just a little while ago but tested them anyway. Checked the sway bar but it looked good. It ended up being one of the front shocks. I guess it was flawed or something because it would make a popping sound when I would drive down the road and I could feel it the floor board.
LGW
2001 F350 XLT 4X4 PSD CC DRW (PMT1), Di-pricol gauges, BTS trans, Dieselsite boot kit, Dieselsite CPR fuel system, DP Tuner F5, AIS, 4"turbo back stainless MBRP T304 exhaust, Wicked Wheel, RS9000X shocks, APC headlights
PMR's
LL still in #8
LGW is offline
Old 02-23-2006, 02:42 PM   #21 (permalink)
Check your u bolts. They do come loose. Check the the little plastic pads on your leaf springs. If your front spindle bearings are shot the axles can also thump around in the hubs.
Build date 9/98 F-250 SD 172" 4X4 7.3PSD 6 speed
188,000 miles, all stock
TIMLUTZ is offline
Old 02-24-2006, 10:59 PM   #22 (permalink)
I have an early 99 F350 . Ihad the same noise under the floor board and it was the body mount bolts.
BMG11 is offline
Old 02-25-2006, 06:51 AM   #23 (permalink)
My Photos: (45)
I will also put a breaker bar on my cab mounting bolts and see if they tighten at all.
"Coming together is a beginning; keeping together is progress; working together is success." -Henry Ford-
2007 F-250•XLT•Black/Silver•CC•6.0•Auto•Fx4•Chrome Package•
Previous truck traded in on 4/2/07:
2003 F-250•XLT•<font color="green">Highland Green</font>•SC•7.3L•Auto•FX4•My Pics.
Jace is offline
Old 03-01-2006, 03:00 PM   #24 (permalink)
installking's Avatar
I JUST GOT DONE TAKING THE SWAY BAR LOOSE AND THE CLUNK WENT AWAY...SO WE TIGHTENED THE ENLINKS UP(THEY DID GO A COUPLE OF TURNS) AND NO MORE OF THE ANNOYING CLUNK...YAAAAAA (AND IT WAS FREE) [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2001 excursion limited black w tan
2008 center console
ts 7 switch chip
4" turbo back
7"superlift
20" ultra goliath 20x9
nitto terra grapplers 355/60/20
viper 7601 alarm remote start w smart start
SOLD....... 2008 xlt crew 6.4 4x4 silver 17x9 kmc spy wheels black 315/70/17 bfg tko
clearshiled paint protection
3m tint 20% fronts 5% over factory rear
uriah products rapid hitch
pionner avicz2 ipod control xm navtraffic
2 pioneer tssw1241d subs custom box around rear seat belt
rockford bd100 amp
edge insight
hid headlights (foglights next)
putco smoked led mirror lights
stay tuned!!more to come soon
87 mustang notchback new 391 cu in stroker dart block jegs/kasse heads turbos or big nos undecided??
installking is offline
Old 03-01-2006, 04:09 PM   #25 (permalink)
My Photos: (5)
Good deal man. Mine ended up being the lower shock mount bolts. They had come loose, so I just re-torqued them and all is well.
2002 Super Duty CC Lariat 4x4 4.5" Donahoe Racing lift
HoustonPSD is offline
