Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-03-2007, 07:03 PM   #1 (permalink)
A/C cool, but not cold???
2006 350 drw, I use for lawn and landscaping so I am in and out of my truck 20 plus times a day. My a/c is a little cooler than than the outside temp. When I push the recirculate button, the a/c cools down, but it is not very cold. Should the a/c be cold on the normal mode or do you have to push the darn recirculate button everytime you get in the truck because it is a PITA!!
4207jeremy is offline
Old 08-03-2007, 07:05 PM   #2 (permalink)
Re: A/C cool, but not cold???
truck has 35k on it by the way, does it need a recharge maybe??
Old 08-03-2007, 07:10 PM   #3 (permalink)
FamilyRide's Avatar
Mines got 51k on it and it's never been touched. It'll make icicles on my ears if I get in sweating. If you're idling a lot, it'll have a hard time keeping very cool. Once I get moving, mine is like a freezer.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 08-03-2007, 07:35 PM   #4 (permalink)
waylntat2's Avatar
My 2004 F250 6.0 is the same , moving cold , standing a lot not very cold, the 6.0 idles low so the compresor turns slower when your idling , and the turbo in in a close place behind the dash .. alot to fight.
,you need to move to stay cooler ,,
2004 F250 SD XLT Fx4 Grey mett. Soft tanto cover, 6.0 PSD Towhaul/Water coolant Filter/custom pinstipes By twisted Image,Highvolts/42.000 miles 2/08
waylntat2 is offline
Old 08-03-2007, 07:44 PM   #5 (permalink)
I bought a bottle of 134a that has a boost additive in it man that helped alot with the AC getting cold faster, now I have to turn down the fan because I get to cold. I bought it at NAPA.
2004 for CC SB white leveling kit plus alittle. 35 toyo'MT's on 18's, Fox 2.0 res. shocks,Air Bags, Edge Juice Attitude Platinum "hot", Dual diamond eye exhaust, Afe stage 2 Intake, ATS tripple loc TC,ATS input shaft, Red Eagle clutch upgrade, transgo shift kit, Shift pressure with HP on the Platinum, Bypass oil filter, FASS fuel system, 90 Hp DDP injectors. ARP head studs. Stage threee fuel system upgrade. 03 turbo...gota love the whistle.
1989 Ford F800 5YD dump truck, 6.6L inline 6 brazilian Diesel, ddp injectors, 5 inch exhaust.
sootballz is offline
Old 08-03-2007, 11:36 PM   #6 (permalink)
My '05 is the same way and has ben since I took delivery. Dealer checked it the first summer I owned it and claimed all was fine. Their is a TSB out that covers an A/C problem on the 05/06 years that has to do with the dessicant stopping up the expansion orifice. Seems to me that it would nor perform at all if this were the case but who knows. My dealer went out of business and it's just too much hassle to go to the next nearest dealer to be told the same old crap about nothing is wrong. I think that I'll just live with it unless it gets unbearable. I am considering purchasing some extended warranty. I've had no problems with the truck so far but as sure as the warranty expires it will start. I've still got about a month and 3k miles to decide.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
jbdawson is offline
Old 08-03-2007, 11:54 PM   #7 (permalink)
Mine started this cold, then cool thing(goes back and forth), and I disconnected the pressure switch and plugged it back in, located by the pass hood hinge. Works perfect now.
twinturbo550 is offline
Old 08-04-2007, 01:28 PM   #8 (permalink)
My 2005 had the same EXACT same problem. Took it to one dealer and they said it checked out fine. A few months later, took it to a different dealer and they said it was about 1/2 pound low. They purged the system and recharged. That was a year and a half ago and still works great.
Make sure the tech guys check your AC with gauges, not just looking at the sight glass.
2005 F-250 Lariat Superduty Powerstroke Super Crew, 4x2
hbattaglia is offline
Old 08-04-2007, 02:26 PM   #9 (permalink)
There is no sight glass and the orifice tube system used on our trucks does not give reliable readings with gauges due to small changes in temp, level of humidity, how long the sytem has run, and what fan speed is used all making big changes in pressure.
Drain and refill accordingto charge label is best followed by a very experienced tech setting controls to a predictable setting and then momitoring temps of suction line evap outlet and suction line at compressor.
When the system is charged properly there will be little difference in those temps when the fan is at a moderate level and the interior temp is 20 degfrees below ambient temp.
Overfilled will give too cold at compressor and underfilled will give too warm at compressor but this is a subjective test based on knowing what it should feel like when it is charged by weight to proper level.
If the service person lets the engine run at idle speed while he is checking then get in truck and leave, he has already shown he is not qualified. Compressor is way below full efficency speed when engine idles and no proper diagnosis can be made then.
Same for checking it if vehicle temps is already too cold inside.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.88 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 feet on the floor Elite/Outlaw LQ horse trailer. Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
Old 08-04-2007, 02:52 PM   #10 (permalink)
is this something warranty will take care ?? Because even on the highway for say 10 minutes or so, it will get warm off and on every now and then and even then its cool, but not always cold
Old 08-07-2007, 10:26 AM   #11 (permalink)
Send a message via ICQ to agdodge4x4
I am not a fan of the climate control system. On automatic, once the temp gets to the setting, it usually kicks over to 'vent'. In texas, in the morning especially, the humidity is so high, its not comfortable on this setting, not only is it IMPOSSIBLE to cool enough, its also very 'wet' feeling. I usually have to manually kick it over to recirculate.
Jason
Texas A&M University
Class of 2002
2005 F-250 4x4 (FX4), Lariat Arizona Beige/Black two-tone, 5 spd Auto, 6.0L.
agdodge4x4 is offline
Old 08-07-2007, 12:01 PM   #12 (permalink)
where is the low pressure side charge valve located at on these trucks?
<font color="red">[b] 2003 F250
6.0 PSD XLT, 4x4 SC FX4 LT265's 3:73 LS/Torqshift
LineX Bedliner Hog Catback Exhaust Virtual Billet Grill Tranny tune by ID
<font color="blue">05/05/03 Build date
<font color="blue"> Anchors Aweigh
tincan is offline
Old 08-07-2007, 03:15 PM   #13 (permalink)
If you are in TX, you have to use the "recir" button to make it cool the truck.
Also, after I took my back in for not cooling FOUR times, they finally found a tech service buletin to add 1/2lb freon to the thing. Made it a LOT BETTER! Ford's AC overall is still way way short compared to all other car companies. My truck has broke down again, and this time they loaned me a Dodge Dakota...........man that thing is COLD
2006 F250 4x4 Lariat CrewCab SB, FX4, 20" w/GoodYears
HoustonPerson is offline
