A/C Fan will only work on high - Diesel Forum - TheDieselStop.com
Old 05-08-2009, 12:53 PM   #1 (permalink)
Hi everyone, I have a 2006 F-250 with the Auto climate control system, The Fan will only work on high, If you try to adjust to a lower speed the fan stops completely, A/C compressor still cycles, does anyone have any idea short of replacing the complete climate control module?
Many Thanks
Ken
Ken260 is offline
Old 05-08-2009, 08:47 PM   #2 (permalink)
Lightningfast01's Avatar
In general the lower speeds go through a set of resistors. High speed is straight 12 volts. In the old trucks it meant your resistor or fan speed block burned out.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 05-09-2009, 06:27 AM   #3 (permalink)
Banned
Does this truck have EATC (electronic panel) or manual temperature control (three dials)?
GrampyJim is offline
Old 05-09-2009, 05:16 PM   #4 (permalink)
jposes's Avatar
I am curious to find a fix for this problem as well. I have the manual (three dial) AC and the fan selector (4 speeds) only works in the last two (high) speeds regardless if it is set to vent, AC, or MaxAC
Black 2002 F350 XLT 4x4 Crew Cab 7.3L (build date 11-01) - Goodyear Wrangler Duratrac 325/65/R18 mounted on KMC XD Monster 18x9 Wheels, 4 inch ProComp Lift w/ dual front shocks, Ranch Hand-Full replacement front/rear bumpers, Leer Camper Shell Autometer Triple guage pillar pod with Autometer Sport Comp Pyro and boost gages, Autometer Ultra lite digital Trans temp gage, DP Tuner (60hp econo, 60hp tow, 100 hp performance) w/ in dash mounted ex switcher, AIS, Bosch Alternator, Viper 3000 alarm, NFab Nerf bars
Cosmetic upgrades: 2010 Tailgate, 2011 power folding/telescoping towing mirrors,
In the works: 2009 FX4 door panels with OEM switches, OEM backup camera and LCD rear view mirror, OEM Overhead console
jposes is offline
Old 05-11-2009, 08:25 AM   #5 (permalink)
Thanks for the replys, the truck has the EATC Electronis controls....
Ken260 is offline
Old 05-11-2009, 11:42 AM   #6 (permalink)
I have no idea how these SD's are set up, but with my Toyota low went out, then 2, then 3, and only high worked. Toyota wanted $50 for a new resistor, so I found a couple replacement resisitors at the junk yard and now all speeds work.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
Old 05-11-2009, 02:27 PM   #7 (permalink)
jposes's Avatar
Where exactly are the resistors located. Couldn't one just take a meter and check the ohms to see if that was the problem assuming you knew what resistance they were supposed to be?
jposes is offline
Old 05-12-2009, 01:35 PM   #8 (permalink)
jposes's Avatar
anybody know where they are at?
jposes is offline
Old 05-14-2009, 09:49 PM   #9 (permalink)
SIC-E's Avatar
having this poblem in wifes town car. thanks for info. now can sound like i almost know sumpin about it when i try to find the resisters.
are they (i'd imagine) located within the climate control module?
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 E350, 7.3l, x-cargo
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
Old 05-15-2009, 01:33 PM   #10 (permalink)
jposes's Avatar
Problem Solved!
Got it fixed! Had to replace the blower motor resistor assembly. Not sure if it makes a difference if you have the EATC (electronic panel) or manual temperature control (three dials) but mine is the manual. The part is listed from 99 through 2007 models but again not sure if it makes a difference on which system you have. I am doing a write up with the part numbers and some pics for those who may find it helpful. I will post it when I am done.
jposes is offline
Old 05-15-2009, 09:34 PM   #11 (permalink)
jposes's Avatar
Got the write-up done. You can check it out here
Download Blower motor resistor replacement PDF @ PDFCast.org
jposes is offline
Old 05-18-2009, 08:15 AM   #12 (permalink)
Thanks for the info!!!!! im going to check mine out now.
Ken260 is offline
Old 05-18-2009, 11:42 AM   #13 (permalink)
Super_Dave's Avatar
I have EATC on my X, and I had to replace that resistor assembly too last fall. Not the worst or dirtiest job at all. Just some time and the part.
Super Dave
2006 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350 Super Duty bus 7.3PSD - Sold
Super_Dave is offline
Old 05-20-2009, 03:49 PM   #14 (permalink)
jposes's Avatar
No problem. Good luck. It sure is nice to be able to run the AC on all four settings again.
jposes is offline
Old 11-06-2009, 11:11 PM   #15 (permalink)
Any easy way to get to the inside nut?
pcryer is offline
