General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
has any one put the cab lights on a truck that did not come with them, I just bought a 2000 and it does not have them and I would really like to. I always put them on my chevys but after the last one I had I wont buy another chevy so I need to learn the ins and outs of the fords.
I was looking into doing this and the ford dealer told me I could not because the roof was double paneled and I would never beable to acces the roof from inside once i drilled through. I was looking for some input on this. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
That explains it!!! Next time talk to the salesman!!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
there are some areas that are double (there is an inner and outer roof panel, but you can access the lights. ford does not put the harness in and weld it shut.
Early 99 (couldn't wait to get my butt in the seat of the new SD) Crew Cab 4X4, 6 speed, AIC, 5" lift, 38X14.50 Nitto Mud Grapplers (awesome mud tire, noisy though), Bushwhacker cutout flares, 4" straight exhaust w/6" tip, open element filter, cowl induction hood, custom grill, stereo upgrade, and most importantly - new style cup holder. 'Pane. H2O soon to come. Kill Record: 1 Honda Accord
Sold the SCMT and replaced it with a DP Tuner, and aint looking back!
I put my own clearance lights on a few months ago. It's not bad, just takes patience and the willingness to drill 15 holes in your roof. I haven't tried installing strobes in them, but I have strobes in my front corners and tail and reverse ligts for the fire dept. The tubes are pretty big and the space in the clearance lights is very limited. I don't see how you would put strobe tubes in them along with the regular light bulbs, especially with the way they stick out on the outside of the fixture. I'm sure it could be done, but you would probably have to drill extra holes in the roof and really know what you're doing. Make sure you get it right the first time!
2005 F250 Harley Davidson
bone stock
www.auto_barn.com has the clearance lights for less than 55.00 a set of five. simple to install. and yes you can put hide-away strobes in them but you have to take the light socket out for the clearance light so all you will have is the strobe bulb in it.
