Cab liner - Diesel Forum - TheDieselStop.com
Old 11-04-2009, 11:57 PM   #1 (permalink)
Cab liner
Will a 2004 supercab roof liner fit a 2000 super cab. They have alot more grab bars.My wife would like that.
dogman1313 is offline
Old 11-05-2009, 10:50 PM   #2 (permalink)
My Photos: (19)
Not sure on actual fitment, but just swapping headliners will get you nothing more than holes in the headliner where those nice grab handles used to go. What you'd need to check is if there is enough metal in the roof of your truck to support those grab handles so they have somewhere to get bolted to.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 11-07-2009, 10:48 AM   #3 (permalink)
That makes sense, I never had the liner out, I would hope the bracing in the cabs would be the same. Does anyone know?
