The Camper Package - Diesel Forum - TheDieselStop.com
Old 06-23-2006, 11:49 PM   #1 (permalink)
My Photos: (14)
The Camper Package
What all does this package consist of?
2000 F-350 Super Cab,Long Box,4x4,7.3L PSD, Bully Dog Chip,6 sp. LEVER ACTION, Camper Pkg.,200k,Lariat, Clearance lights, White on top,Gold on bottom,Gold interior. 285/75/16 BFG's, Dieselsite.com 203* T-stat, alum. T-stat neck and coolant filter kit with Fleetguard WF2077 filter added.
1993 F-250 Reg. Cab 4x4. XLT. 7.3L IDI, E4OD, 4.10 rear, Fleetguard WF2077 coolant filter. Born: 9/92, 163k, Lumbar bench with armrest. White on top, blue in middle, white on bottom. Clearance lights,DeeZee diamond plate running boards to back of cab. True dual exhausts with glasspacks and 4" stainless tips. Pretty well stock except for Pioneer CD player.
rossman is offline
Old 06-23-2006, 11:57 PM   #2 (permalink)
Re: The Camper Package
Rear Sway Bar!!
2001 White Lariat 7.3 Auto CC LB 4X4 -- Mods -- K&N Drop in, DP Tuner, 6.0 IC mod, 4" Magnaflow Exhaust, BTS Tranny, 3 gauge A piller pod. Kennesaw Mountain Accessories Rear and Front “Wincher” Bumper, Warn 16.5Ti Winch, Suspension: Tuff Country 2" front and 3" rear, Toyo MTs 305s on 10s, 310,000 miles!!
05 White XL 6.0 Reg Cab 4X4 140,500 miles!! (That has never seen the inside of a Garage)
06 White 6.0 CC Lariat 4X4 Auto LB: Kennesaw Mountain Accessories Front “Wincher” Bumper, Warn 16.5Ti Winch, Fabtech 8" lift, 35 Toyo M/Ts 125,651 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 36,500 miles---11.491 1/4 mile! 592RWHP
mobeydick is offline
Old 06-24-2006, 08:05 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
On an F-250 PSD:
[*] Heavier-duty front springs, unless the 6,000 pounds @ground front coils were already computer - selected based on other options. The computer usually selects 4,800 or 5,200 pounds capacity front springs, so the camper pkg usually means a slightly stiffer front end.
[*] rear stabilizer bar
[*] rear "overload" springs
[*] Slide-in camper certification. If you don't have the camper pkg, Ford will void your factory warranty if you haul a slide-in camper. So you need this if you might someday slide in a truck camper.
This sort of info is contained in the Order Guides for Ford pickups. You can download your very own copy from www.sunrisefordfleet.com
SmokeyWren is offline
