can I undercoat oil pan? - Diesel Forum - TheDieselStop.com
Old 11-12-2009, 11:16 AM   #1 (permalink)
Hi guys;
Question about undercoating an oil pan...is it ok to undercoat an oil pan on a ford deisel engine? Remember, it costs about 2000.00 to lift the engine or cab to replace an oil pan cover. Ford oil pans are known to rot out after 4-5 years...i've heard that from many ford owners as well as different mechanics..I want to undercoat the oil pan with waxoyl, a product that has been successful in the european market for 30+ years. But I wonder if there is any danger of restricting heat loss through the oil pan, because of this undercoating. I can't see any harm, since the engine already has an oil cooler on it (Ford deisel engines). So the question is, will there be any danger of the deisel engine overheating/damage due to undercoating the oil pan? I am getting the truck undercoated with waxoyl and I thought why not do the oil pan as well? Thanks for any advice. JimmyMD.
JimmyMD is offline
Old 11-13-2009, 07:48 PM   #2 (permalink)
Originally Posted by JimmyMD View Post
Hi guys;
I never heard of the pan to rot out. My truck is almost 10 years old and it looks great. Neither do have to worry about salt on the road either
2000 F250 4x4, superchip, AIS
hucklejack is offline
Old 11-13-2009, 07:53 PM   #3 (permalink)
Supporting Member
my03psd's Avatar
They rot out like wildfire in my area.Lots of salt in the winters.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 11-13-2009, 10:43 PM   #4 (permalink)
OT
OT's Avatar
J..actually this was mentioned sometime ago. I made a note about reports of PSD oil pans corroding, but due to salt. FMC said use MC PM13A Hi Temp. Anti-Corrosion Coating. If waxoyl similiar should be ok? Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
