Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 11-07-2009, 11:53 AM   #16 (permalink)
I just took the entire driveshaft out and changed my u joints right away as well, it easier to work on a work bench then fighting under the truck to get stuff into place.
hhall1114 is offline
Old 11-09-2009, 08:46 AM   #17 (permalink)
dlblazer's Avatar
I dropped the driveshaft yesterday. All of the u-joints are tight and smooth moving - the carrier bearing feels good as well. It turns around the driveshaft smoothly with no lateral movement.
While it was out, I greased the slip spline and got rid of the thud when taking off from a stop.
One thing fixed, but the rattle is still there...
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 11-14-2009, 09:05 PM   #18 (permalink)
dlblazer's Avatar
Its been a good weekend. I finished the gauge install, and then went for round five to try to find the source of the rattle.
While under there I found a black widow spider (or she found me) as she came after me. I had seen webs, but it was a bigger spider than I expected.
After killing her, I went to find the rattle.
I finally found it. It was the brackets holding the air bags to the rear springs. Why I didn't find the source earlier was because the bolts were tight. What they did was install the air bags over the stock overload springs. Then they inserted a bracket under the overload and then secured it with brackets under the main leafs. The brackets between the main leafs and the overloads could move just enough to rattle.
Well I feel better and the truck is nice and quiet.
Thanks for all the help.
dlblazer is offline
Old 11-15-2009, 01:59 PM   #19 (permalink)
Annoying things like can really bug you...at least they do with me. Thanks for filling us in. I always like to find out what the problem ends up being on these type of posts.
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, '08 aluminum differential cover, Inyati bed liner, Edge 3" lift Bonspeed eight spoke wheels w/BFG AT KO 305/65R18s Pics http://community.webshots.com/user/going_going_gone
Going_Going_Gone is offline
Old 11-18-2009, 09:10 AM   #20 (permalink)
0660harley's Avatar
Awesome, glad you found it. I know how incredibly annoying those rattles can be. Thanks for updating.
06 F-250 6.0 PSD Harley Davidson
0660harley is offline
Old 11-18-2009, 12:36 PM   #21 (permalink)
i'm going out on a limb here but if you have bags in the back of youe truck do you happen to have a sway bar back there to cause i an 04 ps and i have what reads to be the same tink as you have but mine was in the front changed the bushings and poof gone not sure if you have one but i'm trying for you
NC_Diesel_20 is offline
Old 11-18-2009, 01:39 PM   #22 (permalink)
My rattle only happens between 100 KPH and 110 KPH - or a large bump - it seems like it comes from the passenger side of the cab at the rear too. Looks like an hour or two on the creeper for me - trouble is - I get dizzy when I do that - almost to the point of upchucking. ANyway - I at least I now know where to look !!!
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
