Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 10-12-2005, 12:49 PM   #1 (permalink)
Can't turn air conditioning off
For the last month or so the air conditioning in my F350 is on full time and I can't turn it off. It doesn't matter whether the switch is set to A/C or vent, the air coming from the defrost/floor/dash vents is cold - I mean A/C cold - and the only way to warm it up is to adjust the temperature control.
Has anyone else seen this? Any suggestions as to how to solve the problem?
Thanks,
Jon
2000 F350 XLT, SC, LB, SRW, 7.3 PSD, 4X4, BTS Tranny, Magnaflow 4" Turbo-back, AIS Intake, Autometer EGT, Boost and Trans Temp Gauges, DP-Tuner 4P Chip, ITP Overboost Regulator, Power Slot Rotors, Bilstein Shocks, Red-Head Steering Box.
jonwpdx is offline
Old 10-12-2005, 02:11 PM   #2 (permalink)
ReefBlue's Avatar
Re: Can't turn air conditioning off
Does the A/C stay on even if you turn the switch to off? If so, the switch may not be breaking the connection to the A/C compressor.
Either that or a relay between the switch and compressor might have failed and is constantly supplying voltage to the compressor.
1999.5 Arizona Beige F250 Lariat Crew Cab at 268,000 miles.
What is this "buying Diesel" people talk about? I run WMO.
ReefBlue is offline
Old 10-12-2005, 02:59 PM   #3 (permalink)
clamgulch's Avatar
as a temporary solution, unplug the compressor clutch. I wired in a switch on mine from the dash because here in washington state, running the air is a waste of fuel most of the time. I use it to defrost the windows until the truck warms up then I just shut it off. Hopefully I'm beating the planned obsollesence routine that way. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 10-12-2005, 05:31 PM   #4 (permalink)
Thanks ReefBlue.
When I turn the switch to the off position the fan stops blowing but I cannot tell if the A/C pump is still active or not. I agree that it is most likely a bad relay, I'm just surprised that the system would fail to an 'on' state instead of an 'off' state.
This could be quite job to troubleshoot so I was hoping that one or more of the TDS members would have already experienced this issue and could provide a leg-up for the job.
jonwpdx is offline
Old 10-12-2005, 05:36 PM   #5 (permalink)
Good idea ClamGulch, that will solve the problem for the short-term until I have time to do the complete job.
Jon
jonwpdx is offline
Old 10-12-2005, 06:02 PM   #6 (permalink)
[img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] I have run just over 100,000 miles in my truck and notice 0 difference in MPG with AC on or off. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
With the power of the PSD and the efficiency of Modern AC Compressors you may see saves in the 1/10's of MPG. But I have not seen any change.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103 Pictures
www.CarpathiaHost.com
Wayne B is offline
Old 10-15-2005, 10:37 AM   #7 (permalink)
Send a message via ICQ to 96Cobra
Thanks,
Jon
You do know that the AC compressor will run in every position except vent and floor, right? Are you getting AC air out of these 2 positions also?
Roger
2002 F350 XLT, CC, SB, 4x4, Auto, AIC, DiabloSport Predator, BD X-Monitor, Kenwood TM-V7A, Pioneer 7400MP3, Infinity 5.25" Components, Infinity 10" Sub in a Q-Logic Box, Heated Mirrors, Gentex/Mito Auto Dimming Mirror, Rear ID Bar, Uniden PC78 Elite CB, Clifford Matrix RS3 Alarm/Remote Start, Keypad Entry, Homemade "Tymar", custom, muffler back exhaust, 6 Whelen LED's in rear window, 6 Whelen Strobes in the Front, Rears still not installed...
96Cobra is offline
Old 10-16-2005, 12:52 AM   #8 (permalink)
Thanks,
Jon
Roger
No, I didn't know that, I would expect the A/C compressor to run only in the A/C or Max A/C positions. I get A/C out of every position except Off, and I can't be sure that the A/C compressor is not running in the Off postion because no air flows through the vents at that point.
My concern is two-fold:
1. I generally like to drive with the vents providing ambient temp airflow from the outside, but with the A/C running all of the time the air coming in is too cold.
2. If the A/C compressor is running constantly, it is bound to fail prematurely and it can't be cheap to replace.
Although I've only had the truck since June, I don't remember the vent air coming out cold unless the switch was set to A/C or Max A/C.
jonwpdx is offline
Old 10-17-2005, 05:48 PM   #9 (permalink)
Bump
jonwpdx is offline
Old 10-17-2005, 06:39 PM   #10 (permalink)
[quote
Roger
Roger is right, i was told on my 99 that the ac is always on to keep mold from builing. i thought my thermostat was busted and took it in, thats how i found out about the vent and floor being the only ones that didnt have the ac on all the time.
check to see what your interior temp is set at. my new truck adjusts the temp even w/o ac on, by what i have the interior set to.
2005 F350, 6.0l, CC, LB, FX4, Lariat,
Loaded with every option, Az Beige, Line-X,
2005 29' Thor Fury toy hauler
Sold 99 F250 V10, CC, LB, XLT.
2001 Jeep Wrangler Sport
4" lift 33" Dick Cepek FCII
The wife's (I get visitation rights to it)
More dirt and mud than road...
F350
jeep
toys
old truck and TH
acjjkamp is offline
Old 10-18-2005, 11:02 PM   #11 (permalink)
Thanks guys, I appreciate the info.
jonwpdx is offline
