cracked radiator - Diesel Forum - TheDieselStop.com
Old 12-22-2012, 06:47 PM   #1 (permalink)
cracked radiator
i stupidly cracked my radiator and was wondering if JB WELD would hold or is there too much pressure? i put a hairline crack on top next to the shroud mount. i was lifting the engine and forgot to pull fan AND shroud off. OOPS!!
1999 f350 7.3 6spd; 243k miles no mods
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
tickedoff36 is offline   Reply With Quote
Old 12-22-2012, 07:20 PM   #2 (permalink)
RT
RT's Avatar
Doh!
JB Weld might hold for a day or two, but it will never make it long term. Too much expansion and contraction. New radiators aren't that bad - Spectra makes a nice one.
SPECTRA PREMIUM / COOLING DEPOT Part # CU2171 is $141 at RockAuto
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 12-22-2012, 08:33 PM   #3 (permalink)
problem IS no job-no money and if i did replace i would try for an ALL metal one. i might try to find someone to weld it for me. i only know of one guy and he is 300+ miles away and is likley snowed in.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 12-25-2012, 01:18 PM   #4 (permalink)
big_blue's Avatar
i jb welded my wife's explorer radiator in the summer and it's still just fine. i say try it, you ain't got nothin to lose.
worst case you wind up replacing it.
'99 F250 PSD 4wd CC LWB, 390+K Hard Miles!!!
Never been in the shop in it's life!!!
big_blue is offline   Reply With Quote
Old 12-25-2012, 04:30 PM   #5 (permalink)
i was going to try anyway. like you said -nothing to lose- i also would like to know if there is a seal between the top of the tranny and the shift plate. where the stick bolts to the top (6 bolts)??
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 12-25-2012, 06:28 PM   #6 (permalink)
Junk yard.
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
rock_doctor is offline   Reply With Quote
Old 12-25-2012, 06:42 PM   #7 (permalink)
what do you mean junk yard - nothing is cracked just want to know if that cover has a seal on it if not RTV'ing it.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 12-25-2012, 06:50 PM   #8 (permalink)
badbart's Avatar
I think he was referring to your radiator.
1997 F350 XLT Crew Cab Dually, 7.3 Powerstroke, 4:10 limited slip, K&N Air Filter, MBRP 4" Turbo back w/muffler, Edge programmer, Billet torque converter, Monster tranny cooler.
2004 Cadillac CTS V 5.7 LS6, Tremec 6 speed,
K&N Cold Air, Magnaflow Exhaust, MSD Ignition,
LS7 clutch, Getrag 3:73 posi-trac, 377 RWHP
badbart is offline   Reply With Quote
Old 12-25-2012, 07:09 PM   #9 (permalink)
i do NOT do junk yard unless i absolutly have to. have had too many bad things from junk yards. good luck a few times. i will just JB it in the meantime. something like rad and moving parts i prefer new. no yards around here any way, closest is 80 miles.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 12-25-2012, 08:06 PM   #10 (permalink)
Yep i shortened the post too much (thanks badbart)...i always forget people can't hear the voices in my head... You may be able to get a good whole rad or at least a replacement tank from a bone yard.
Car-Part.com--Used Auto Parts Market
They will pull it and ship it to you. I have used Marine Tex in the past for everything from cracks in engine blocks to screw holes in boat hulls. I swear by the stuff. It is about the same idea as JB weld. Scuff up the area with sand paper and marine tex or JB it... Good luck.
Old 12-25-2012, 09:12 PM   #11 (permalink)
it is only a hairline so scuff and JB
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 12-26-2012, 07:32 AM   #12 (permalink)
If all it is, is a fine crack that weeps when at pressure then i would bet the JB would fix it just fine. Years ago i broke the overflow nipple off the brass radiator in my surburban, Marine tex'ed it back on and it held until i replaced the rad due to core leaks.
