Crew Cab Short Bed with a Flat Bed? - Diesel Forum - TheDieselStop.com
Old 11-05-2009, 04:44 PM   #1 (permalink)
Hello all,
I have a 2001 F-250 Super Duty Crew Cab with a short bed. Living in the Northeast, I have just started to get the typical bed rot on both sides of my short bed. I started to think that this might give me an excuse to put a flat bed on the truck with a few tool boxes.
Has anyone else put a flat bed on a short bed? I see them all the time on duallys and 8ft beds, but I haven't seen one on a short bed. The short bed is six and a half feet, but could a flat bed go out to seven feet? I still need to tow so I am guessing I wouldn't want to go much farther out.
Any pictures? Any ideas from you all?
thanks,
Alex
2001 F-250 Super Duty Crew Cab 285,000 miles AIS Intake
Binkowski is offline
Old 11-05-2009, 05:49 PM   #2 (permalink)
rdvit94's Avatar
Wow, I'm surprised it took that long. The bed on my 2001 rotted out 2 years ago. Have you thought about buying a take off bed from an '08 or '09. They are readily available, that's what I did and it was cheaper than having the rust fixed.
2001 F-350 XLT, CC, LWB, 4x4, Auto, Off-Road, DP-Tuner (stock-40-80-120), SP Diesel Air Intake, MBRP 4" Exhaust, Banks BHA, TAG, Dieselsite BRV, AIH Mod, 203 Stat, Sonnax/Tri Kit, Tank Mods, Redhead Steering Gear, DB Electric Starter, Di Pricol Gauges in A-Pillar, 3.5" Custom Lift, 315/75/16 BFG ATs, Delta Toolbox
Truck Pics
rdvit94 is offline
Old 11-05-2009, 06:34 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
I see shorty SRW flatbeds often. As long as you have stake pockets for sideboards and a tailgate, then they work fine. The sideboards and tailgate don't have to be any higher than 2x4 or 2x6 lumber, but without at least some sideboard and tailgate, you'll have cargo rolling off the bed too often.
You can mount underbed storage cabinets on the passenger side. With a shorty, there won't be room on the driver's side for much of an underbed cabinet after you make provision for the fuel filler tube to be accessable. You can also mount tool/storage boxes on the top of th bed, across the front and down both sizes, if you choose low-profile boxes not more than about 18" or 19" high.
Your local truck body retailer probably won't have a shorty flatbed in stock, but he can order it from several different suppliers, including the big names of Omaha Standard, General Truck Body, Knapheid, Reading, Stahl or Supreme. Or there's probably a local truck body welder-upper near you that your truck body retailer can order from.
One caveat is that the beds for pickups and chassis cabs are much different. One won't fit the other. So the shorty spec should be enough warning to the supplier that you have a pickup with the bed removed and not a chassis cab. But just in case, spell it out for him.
Most decent-sized towns over about 100,000 population should have a local truck body retailer. Look in the yellow pages under truck bodies.
You want not more than 48" distance from the center of the rear axle to the back of whatever sticks out behind the bed - usually the rear bumper and the receiver. Then you can mount a fifth-wheel slider hitch 2" in front of the center of the rear axle and still be able to turn sharp corners without trailer to rear bumber contact or - with the hitch slid back - without trailer to cab contact. So that means about a 7' long bed is the max you can go for if you need to tow a fifth-wheel trailer.
If your trailer will be a tag, then you could go with an 8' bed as long as you always use a weight-distributing hitch tightened up to transfer at least one third of the hitch weight to the front axle of the truck. If you don't want to use a weight-distributing hitch for gross trailer weights less than 5,000 pounds, then limit the bed length to 7'.
SRW pickups have a weight problem. Your GVWR ain't much. And steel flatbeds are heavy, which doesn't leave you much capacity for hitch weight. So if you want to haul normal trailer loads, then get an aluminum bed instead of steel. A lot more expensive, but a lot lighter.
Last edited by SmokeyWren; 11-06-2009 at 02:44 PM. Reason: confused inches (") and feet (').
SmokeyWren is offline
Old 11-06-2009, 11:12 AM   #4 (permalink)
Will a newer (08' or newer) bed fit onto a 2002 F-350 CC SRW? My wheel wells are starting to rust through, bubbles under the paint, and with the cost of repair I thought that a replacement might be a better idea.
2002 F 350 4x4 Crew Cab Lariat
7.3 Diesel 6-speed manual
206,000 miles
All Stock, Possible Chip?
schoolde is offline
Old 11-06-2009, 12:07 PM   #5 (permalink)
Good info
Thanks SmokeyWren. That's very useful information! I was actually playing with the idea of trying to modify an aluminum snowmobile trailer. They are all over the place up here and I always thought they look to be the same size as a flatbed would be on this short bed.
I regularly Rowing shells so the loads aren't that heavy but the bed sides can get a little close with the lower racks on our trailers. Defintiely don't need a steel flat bed.
