General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
2000 F-350 7.3 PS ,4R100 Lariat Dually http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
Wicked Wheel
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using SCT 100hp Performance tune.
Wastegate disconnected for now...
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Camera,DVD,Nav.,Satelite Music.
Jason smooth topper.
Here but not installed: 4'' Ported Housing,ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.,TRU Cool tranny cooler (no time )
It is on the news 1994 thru 2003. Faulty cruise control switch made by Texas instruments. Same switch as before on other models. Recalling as a precaution accordlying to Ford
How much disassembly of the colum will replacing that switch require, I am wondering if it would be a good opportunity to replace the harness that is known to chafe.
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 133K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dieselsite coolant & tranny filters, ITP pre pump tank mod, netbook mount with AE.
Ford Recalls Super Duty Diesel trucks 93-97, 99-03
Looks like the burn down has gotten some attention..
Tuesday's recall includes the following Ford models: 1995-2003 Windstars, 2000-2003 Excursion diesels, 1993-1997 and 1999-2003 F-Super Duty diesels, 1992-2003 Econolines, 1995-2002 Explorers and Mercury Mountaineers, 1995-1997 and 2001-2003 Rangers and 1994 F35 motorhomes.
I know many of these switches are under the hood, but i had the switch under my dash go bad. i ended up by passing the part where the clutch auto disengages the cc. Is this the same part?
"Ford is notifying customers and instructing them to take vehicles to dealers for a complimentary installation of a fused wiring harness that will eliminate the risk of fires, the NHTSA said."
Sounds like some fix.... not.
IT IS MINE ALL MINE.....(The Van that is, it has been Released by Lenholder)
It is a Very wet fall. Might need Hip waders. Next on the list is Snow, and that could be any day.
CNN said this will start on Oct. 26. I guess they need time to ship harnesses Sounds like fuseable link harness so if part does fail it just blows fuse instead of burning truck to ground. So keep that in mind if fuse blows they still need to replace the troubled CC switch for free if it does fail, I would think ?
Stopped by my Dealer today with my '97 F350 PSD and they looked at the part and then placed a new fused harness between the plug and the existing cable that was plugged onto the switch. Took all of 4 minutes to do.
Got to go back with my '02 F350 PSD for them to check that one.
Dick
__________________ TheDieselStop.Com Photo Editor/Moderator
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, XM Satellite Radio - Currently 11/09 - 235K miles
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, CD and XM Satellite Radio - Currently 11/09 - 165K miles
Does any one have any idea as to the cost of the part in question?
This Band-Aid way of life is sick....
Fix it right the first time and enjoy life more.
