1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
If the switch goes back with the fuse link ,,, the link goes, then you have to replace both the link and the switch... and guess what? you and I that have the switch go bad and blow the fuse then get to pay for the time and the switch...
Winter is here again, and yes I mean WINTER.. the temps are likely to reach -25F and then there is the snow and the dark.
2000 E350 7.3PSD, Hellwig Stablizer bar,140 Lightforce with covers, 55Watt High/Lows HID's , extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E Toyo Open Country, My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
IT IS MINE ALL MINE.....(The Van that is, it has been Released by Lenholder)
weird how I posted this thread and now it has a new name and I am the second one.
When threads on the same topic are combined by VBulletin software, the posts are placed in the new thread by posting time. So you were the second member to post the similar topic, and thus your post wound up second in the combined thread.
I stopped by Wabash Ford in Indy (PowerStrokeShop) and had the recall work done. Took less than a half hour from the time I walked in until I was back on the road again. They did tell me that part of the recall was to check for brake fluid inside the harness connector, if detected then the switch is also to be replaced.
so the presence of brake fluid in the connector gets the switch replaced? hmmmmm....(reaches for can of brake fluid)
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
I stated it the same way that the tech said it to me. I didn't ask him to clarify, so I don't know if that meant that the switch would be a free replacement though.
i anyone wants to run their vin to double check the recall before going to the stealership: Recall Information - Ford
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, RECON LED TAILGATEBAR W/ REVERSE LIGHT, BUG GUARD AND WINDOW VISORS. 05 GRILL AND HEADLIGHT SWAP, 08 TAILGATE, 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS. 5% TINT ALL THE WAY AROUND, AND 50% ON THE WINDSHEILD.
SOON TO COME: 08 TAIL LIGHTS, CLEAR CABLIGHTS, RECON ESCALADE STYLE 3RD BRAKE LIGHT, STROBE LIGHTS, PROJECTOR BACKUP LIGHTS, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
I had mine done yesterday AM. From hood open to hood shut, less than 10 minutes. They inspected the switch, then added the fusible link harness. I asked a few questions about it, and was told that if the fuse blows, it's due to the switch issues. When it does blow that this same recall will cover the repair at a later date. Although I do find this hard to believe, since when I gave the pencil pusher behind the computer my VIN to run it, he told me they were only going to do an "inspection" and not add the fusible link. But luckily the tech knew better!
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
Sounds like you guys have better dealers than what I have. I took mine in last friday for the CPS and the Cruise recall and they had the truck for about 2 hours! Not a big deal to me, but come on...it shouldn't have taken that long! For the cruise thing, they said mine was fine and simply added the harness. I noticed the fuse in the harness, but didn't ask what I should do if it blows....good to know what to do now.
__________________ 2002 F-250
Lariat, CC, SB, 4x4 w/Off Road pkg, 7.3L, Auto Trans, 3.73 LS, AIS, Zoodad w/prefilter, Autometer Ultra Lite Boost, Pyro, Trans Temp & Fuel Pressure Gauges, Walker BTM, IC Tube Foil Delete, DR 2" Leveling Kit, BFG A/T 285's, Door Seal Mod, Tranny Magnefine, ITP's "Hutch" Mod , Harpooned Tank, 4" rear blocks, ITP Overboost, DP-Tuner F6 No Start, Stock, 80E & 80T, 60E, JW Valvebody, Front & Rear PowerSlot Cryo Rotors w/Hawk LTS pads, Bilstein Shocks, Dieselsite Boots, Dieselsite Coolant Filter, Dieselsite 203* T-Stat, Prestone ELC, FRx R/R, Bellowed Up-Pipes
To Do/Wish List: ATS Compressor Housing, Adrenaline HPOP, MBRP 4" Turbo Back Exhaust
Well, I had one of those fuses in the new harness blow sometime within the last week. Cruise worked one day last week, but went to use it over the weekend an nothing happened. I check both 2A fuses and one was blown. I didn't check the switch yet for fluid, but I'll be calling my dealer to see what they have to say. They better be replacing that switch for free!
