Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-06-2008, 04:15 PM   #1 (permalink)
Question Cruise light out, but bulb OK
About a month ago I lost my cruise-control indicator light on the instrument panel. The cruise control itself works fine, but the indicator light doesn't come on. I thought for sure it was just a burnt out bulb, but when I finally got around to replacing it today, I discovered that the bulb is OK. It tests OK and works in a different position when I swap it with another bulb. I thought maybe the bulb just wasn't seated properly, but I took the truck for a test drive with the bulbs in swapped positions and it's the same story--cruise control works, indicator light doesn't. Anybody got any ideas?
Early 99 F-250 4X4 Lariat SuperCab SB with 2002 Lance Model 821 camper; Rancho 9000 shocks, Firestone air bags, Hellwig front & rear sway bars, Mag-HyTec tranny pan, shift kit, Alpha bed liner, manual Warn hubs, Airaid intake, Walker BTM, HyperTech programmer, TruCool tranny cooler, 19.5" Rickson aluminum wheels, TruSpeed recalibrator, X-monitor, '03 headlights.
JerryKing is offline
Old 08-06-2008, 06:07 PM   #2 (permalink)
Totally mystified
OK, now I'm really confused. If you think I'm nuts after reading this, I don't blame you.
I pulled the instrument cluster completely off so that I could inspect the backside. It's easy to trace the printed circuit connections on the back and see where they go. One contact of the cruise indicator light connects to a printed circuit path that is obviously ground, as it is common to all of the lights. The other connects to a path that leads to pin 13 (4th from the left) of the center multi-pin socket. The mystery is that the corresponding multi-pin plug has no contact and no wire in location 13, and I double-, triple-, and quadruple checked to make sure I was looking at the right plug and the correct orientation. The wear pattern on the socket contacts verifies that there never has been a plug (male) contact inserted at that location. So, there is no path for power to the cruise indicator light, and there never has been. The problem is that it was working until about a month ago. Honest! No, really, I saw it with my own eyes!
They're coming to take me away, hee-hee, ho-ho..............
Old 08-06-2008, 10:24 PM   #3 (permalink)
I'm assuming the bulb is burnt out. You may want to check your fuse box before you consider replacing the bulb but ultimately, that'd be my guess
____________________________
Spot the Autopartswarehouse.com
Drive Safely and Move Freely
khooper is offline
