1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Did a search, but nothing came up. 2004 f250 cc. 6.0l . I was wondering if there is a way to make the dash lights brighter? Maybe add some more, or change out dimmer pot or something? Figured someone on here has already done it. Thanks in advance for your help.
The lamps in the instrument panel and in the A/C cluster are a stock 2W #194 lamp. Change these out to a LL (long life version if you can find it) 3W # 168 lamp. This will brighten up your dash lights.
2001 F-250 4X4 CC SB 7.3 4R100 3.73, BFGoodrich All-Terrain TA/KO, Motorcraft filters, Mile Marker manual hub locks w/ESOF (No hub "floating"), AIH delete, Rust-Oleum bed coating, Silverstar Ultra headlamps w/ clear headlight assemblies, 5,000K LED interior lamps; Moog greaseable u-joints, ball-joints, front hub assemblies; retractable bed hitch, original black CPS (BEST "mod" I have), Energy Suspension bushings, Red Heavy Duty ELC, Edge Evolution 15001 (for gauges), Walker BTM, Donaldson AIS
I second replacing all of the dash bulbs. I did this about a year ago and it made a HUGH improvment.
__________________ FOKISD Charter Member from Hillsboro, OHIO
'01 F-350, XL, SC, LWB, V-10, 4R100, 3.73 LS, High Back Buckets, TT Mirrors, Roof Lights, Camper Package - Check my Photo Gallery for modifications. Michelin LTX M/S 2's on Mickey Thompson Classic II's, A.R.E. DCU cap, Reese Titan V and Draw-Tite front reciever, Audiovox cruise control, Wolf center console, Truck-Lite rear ID bar, Hella FF75 driving lights. Bilsteins on each corner.
I'd have to look at the pictures I took while I did it. I'll post the picture when I get home tonight.
Seems like a dozen or less bulbs were needed, but I only replaced the cluster illumination lamps, not the indicator lamps. The attached pictures show the back of the cluster, and the other pix shows a lamp and holder once removed. The color of the holder has no bearing on the lamps function. The old bulbs had a silver coating on the inide of the glass, causing them be dim - probably vaporized material from the bulb filament.
I just bought a 2006 F-250 6.0L I can't see instrument panel in day light. Deal er say this is normal. How can I increase back lighting during day time. It's like looking into a black hole during day light.
