Diesel Ringtone for my Phone - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 02-14-2006, 03:58 PM Thread Starter
MikeD's Avatar
I am looking for a downloadable ringtone of an idling diesel. I would prefer the 6.0L if possible. I just got a new phone and have never done this before. Thanks for any help.
Mike D.
2006 F350 Super Duty 6.0l PSD, white CC SRW LineX
MikeD is offline
post #2 of 16 (permalink) Old 02-14-2006, 06:15 PM
Re: Diesel Ringtone for my Phone
Well depending on what service you have I think the options are real limited. I have a nextel and the only thing they had is a corsa durcrap...2 options. It sounds pretty good and I was real surprised to hear it.
2004 F250 Auto
Airaid Intake
4" MBRP turbo back exhaust no kitty and no muff diving
SCT from Innovative
Independentreb12 is offline
post #3 of 16 (permalink) Old 02-14-2006, 09:53 PM
try this link, www.matrixm.com I downloaded a cummins ringtone fom here. Do a search for diesel and there you go!
2003 7.3 SD, CC, 4x4 with FX4 package, white and 100% stock
benco57 is offline
post #4 of 16 (permalink) Old 02-15-2006, 09:09 AM
Can anyone send me the cummins ringtone?? I can pm you my number.
TIA
Magnaflow has some free ones.
http://www.magnaflow.com/ringtones.asp#download
06' F-250, 6.0L PSD, AUTO, CC, SRW, SWB, 4WD, ESOF
4" turbo back MBRB exhaust
x-monitor
Air horns
cvucich is offline
post #5 of 16 (permalink) Old 02-15-2006, 09:32 AM
KML
Now can you get it to [img]/ubbthreads/images/graemlins/smokin.gif[/img] too?? [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
I like it!
2001 F250 CC, Lariat 4x4, exhaust, chip, PS2K propane, Line-x, etc.
KML is offline
post #6 of 16 (permalink) Old 02-15-2006, 10:53 AM
Does anyone have a FORD diesel wav file or mp3 file? My phone is a Treo and will use anything for a ring tone. I would like a sound of one standing on it, turbo howling! [img]/ubbthreads/images/graemlins/smile.gif[/img]
2002 Toredor Red F-250 CC PSD 6 speed 4wd
Wicked Wheel/Big Head wastegate/Homemade Tymer Intake/4" Dynomax Exhaust
2.5" Rubicon Express Lift/F-350 Rear block
Bilstein 5100 Shocks
Detata Ounce 17X8 Wheels
35X12.50 Mastercraft Courser CT Tires
DP Tuner
1969 Ford Bronco, 351 Lightning EFI, C4, Atlas II, HP Dana 60 front, 9" 35 spline/daytona drop out/spooled rear, Custom cage, custom suspension, Warn HS 9500I winch, 40x13.5 BFG Sticky Krawlers, custom interior, Permier Power Welder
cobronco69 is offline
post #7 of 16 (permalink) Old 02-15-2006, 01:01 PM
iwejun's Avatar
Stroker I use a little program by Handango called Ringo, it will play the tones.
07' 6.0 Lariat,350, DRW,CC boney stock (not anymore)
Pullrite Superglide, Sandpiper 32BHSS Platinum
2007 Four Winns 224
" LET'S ROLL !" Todd Beamer-Flight 93
The Lord has plenty of messengers, what's really needed are listeners.
Dieselsite Coolant Filter
BulletProof EGR
BulletProof remote oil cooler
MagHytek Rear Diff. Cover
HID Headlights
All LED lights inside and out
BullyDog GT2
MBRP
A1 Head bolts
Black Diamond Head Gaskets
iwejun is offline
post #8 of 16 (permalink) Old 02-15-2006, 01:15 PM
klhansen's Avatar
My Photos: (180)
How would you hear your phone ring when you're driving? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I've thought of using a diesel ringtone too, but am too cell-phone challenged to even attempt it. My phone just lets me make and recieve calls.
If you have a microphone and a laptop, you can record your own wav file. [img]/ubbthreads/images/graemlins/cool.gif[/img]
On edit: I almost forgot about the PSD startup sound I have on my computer. Check your e-mail. [img]/ubbthreads/images/graemlins/cool.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #9 of 16 (permalink) Old 02-15-2006, 01:25 PM
Check the downloads section right here:
http://www.thedieselstop.com/downloads/index.php3
Phil
2002 F350 Lariet 4x4 CC SB 7.3
PhilF350 is offline
post #10 of 16 (permalink) Old 02-15-2006, 01:27 PM
olddieseldude's Avatar
My Photos: (16)
Here's the one from the TDS downloads page...
diesel idling
downloads index
RickN
(mods listed in comments under photo in above link)
olddieseldude is offline
post #11 of 16 (permalink) Old 02-15-2006, 01:52 PM
How do you put one of the tones listed above on my phone, I dont have a clue. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 F-450,Crew Cab,4x4,Flatbed,4.88 diffs
Sumitomo 245/70R19.5--Centramatic balancers--AIS with Fender Sleeve--Chrome Simulators/Dieselsite--Coolant Filter/Dieselsite--Trans Filter/Dieselsite-- A-C valve/Dieselsite --Oil Gaurd bypass filter--Fumoto valve/Dieselsite--SkyJacker Steering Stabilizer-- 4 Gauge A Piller Pod(pyro,boost,trans,volt)--Muffler delete--AIH delete--Gas Magnum shocks--ITP HX mod--Wolverine Engine Oil Heater--GOLD coolant---CCV mod---ITP Pre pump/tank Kit---WIX prepump Filter/Separator---FIA grill cover---Zoodad Mod---REDHEAD steering box---ROTELLA 5-40 Synthetic---MOBIL 1 syn PS fluid---Magnefine PS filter---STACK single/chrome/5"---
ON THE FLATBED>-- Miller Trailblazer 302-- Suitcase MIG 12vs x-treme-- 2 60" boxes/ 2 36" boxes-- and all the necessities
SKEET298 is offline
post #12 of 16 (permalink) Old 02-15-2006, 07:33 PM
VERY COOL!! I got my wife to do it and works great. Had to download as a mp3 file, got it from the magnaflow website posted here. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SKEET298 is offline
post #13 of 16 (permalink) Old 02-16-2006, 01:11 PM
doczenith1's Avatar
My Photos: (11)
For Nextel users get a usb data cable and this cd from ebay. One common mistake when using the software that comes with the cd is not telling the software to use the usb port instead of the com port. The software will allow you to transfer wav and mp3 files to your phone. You might have to convert them to the proper bitrate first though. PM me if you need assistance converting mp3 files for use with nextel phones. I would imagine the guy selling the cd has converted all the ringtones contained on the cd for you.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
SOLD
2003 Mustang SVT Cobra, black convertible. - 6/2007 - 9/2013
SOLD: 2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #14 of 16 (permalink) Old 02-16-2006, 04:55 PM
Now this has me wanting the engine sound on my phone...
My problem - I have to message a ringtone to my old Motorola v60i. It's an imelody format (imy), which is pretty close to midi.
.wav and .mp3's won't work. Does anybody have a tool or a link to one which will convert an mp3 or wav to an .imy or .mid file?
Phil
PhilF350 is offline
post #15 of 16 (permalink) Old 02-16-2006, 05:26 PM
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
Can't really do that. wav and mp3 are encoded versions of actual audio. imy and mid are like sheet music. They only tell HOW to play the song, but the sound will always be a cheap approximation of beeps for notes, depending on the quality of the midi instrument database. You'll never hear vocals with a mid or imy file. mp3 and wav could record anything from a diesel engine to a duck fart. Only cellphones with a diesel engine and duck "instruments" would be able to reproduce mid or imy notes. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
sorry- [img]/ubbthreads/images/graemlins/frown.gif[/img]
-steve
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font>
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
SteveRacer is offline
