DieselKleen question/Thanks for all the reply's...:( - Diesel Forum - TheDieselStop.com
Old 03-06-2005, 11:29 AM   #1 (permalink)
I messed up and filled the tank without adding the DieselKleen first. Question is can I go ahead and add it now or do i have to wait for another fill up? Also It says on the bottle to add the 32oz to 50 gal. to briing the cetain level up 6. I have a 38 gal tank would it hurt to put the whole 32oz in?
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Roger
Early 99 Black F-250 7.3 SD, CC, 4X4, Automatic, Short box. 258.000 miles.Firestone air bags rear and on board compresser W/in cab controls. Line-X sprayed in bed liner. K&N Cold Air,Aluminized 4"Turbo Back Magnaflow,Mirror upgrade to TT heated electric. All new 2004 interior from headliner to carpet. In dash popup pioneer 7" TV/CD/Stereo.Back seat pioneer 20" fold down TV/DVD/Gaming screen. Juice with Attitude and Edge Evo.Phantom tranny temp and boost gauges by AutoMeter. TURBONETICS unique patented Ceramic Ball-Bearing Turbo and Late 99 pedestal upgrade from www.puredieselpower.com
New BTS tranny installed 2/2/06 Put a brand new engine in 11/03/07
DeltaEx is offline
Old 03-06-2005, 05:48 PM   #2 (permalink)
NCHornet's Avatar
Re: DieselKleen question/Thanks for all the reply's...:(
Well if my math is right you should be using 24 oz for your size tank. I also have this tank and that is what I use. This is the strong measurement, they also give one at half this strength. I bought a nice funnel at Walmart that haz the oz markings on the side, it has a long flevible hose on it with a shut off valve, you simply twist it and it is closed, fill the top to 24 oz stick the hose in the tank and un twist the valve and it dumps it in the tank. You can add it now after a few miles it will mix itself in just fine. I hope this helps.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 03-06-2005, 06:34 PM   #3 (permalink)
Hornet I really appreciate you answering me! My questions should be simple enough for you long term Diesel guy's but i can never get anyone to answer me right away.. So, again thank you!
Roger [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
DeltaEx is offline
Old 03-06-2005, 08:05 PM   #4 (permalink)
I often add DieselKleen after the fill up....no reason, but no problems either. My two cents worth! [img]/ubbthreads/images/graemlins/smile.gif[/img]
2012 F350 SD CC Lariat PSD Leather - 3.55 gears - E-Lock - 6 Speed Auto...Pullrite 16K Super Glide, 2010 Jayco Designer 35 RLSA 5ER
2005 F350 SD CC Lariat PSD Leather - 3.73 gears - 5 Speed Auto...Pullrite 16K Super Glide, 2010 Jayco Designer 35 RLSA 5ER
1999.5 F250 SD SC - AFE Stage II intake, TS Performance 4 Position Chip (50-75-100-125), 4" Catback exhaust, AutoMeter Pillar mount gauges. Tru-Cool Max Transmission Cooler, Firestone 2330 Air Bags. Pullrite 16K Super Glide, 2005 Wilderness Advantage 295 RLTS 5er
joggerman is offline
Old 03-06-2005, 10:09 PM   #5 (permalink)
HeavyAssault's Avatar
My Photos: (6)
I use the entire quart per fill-up, I haven't had any issues or complaints.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is online now
