DIH Parking Brake Pictures - Diesel Forum - TheDieselStop.com
Old 02-08-2010, 06:55 PM   #1 (permalink)
FMTRVT's Avatar
My Photos: (16)
Often people have questions about the DIH brake and I found some pictures that I had. I threw them up in a Webshots album in case some people want to bookmark it for future reference.
Ford P131 DIH Brake pictures from trucks photos on webshots
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 02-09-2010, 11:10 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
For the newbees, "DIH" = drum in hat, which is the drum brakes inside the rear disk brake rotors on '99-up SuperDuty pickups. The DIH brakes are the emergency or parking brake on our trucks. I don't see the disk rotor in the photos Jack linked to, but I'm sure they're there somewhere.
SmokeyWren is offline
Old 02-09-2010, 11:38 AM   #3 (permalink)
There are some pictures here
Superduty 99-04 to 05+ brake comparison pictures from cars photos on webshots
444-4D is offline
Old 02-09-2010, 12:07 PM   #4 (permalink)
FMTRVT's Avatar
My Photos: (16)
Originally Posted by SmokeyWren View Post
....... I don't see the disk rotor in the photos Jack linked to, but I'm sure they're there somewhere.
Everybody's a critic. Your right Smokey, I'll unbox some of the rear rotors I have in the garage and get some pictures.
Jack
FMTRVT is offline
Old 02-09-2010, 12:22 PM   #5 (permalink)
When you adjust the prking brakes do you turn the star "up"? Mine won't hold anymore. They probably need to be replaced and the limited slip needs to be rebuilt. Would be good to do them at the same time I'm guessing.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 60000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 185,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline
Old 02-09-2010, 12:27 PM   #6 (permalink)
You don't like my pictures?
444-4D is offline
Old 02-09-2010, 03:10 PM   #7 (permalink)
Are dually's the same?
'00 F350 XLT, DRW, CC, 7.3 PSD, 6 speed, combo 90 gallon fuel tank/tool box, Banks Stinger-Plus, 203º T-stat, A-Pillar ISSPRO guages, Hadley Air horn, PowerSlide rear window, AIC, AIS, KCM S.S. HPX Line, Riffraff FRx.
Member # 10965
HorseHauler is offline
Old 02-09-2010, 04:34 PM   #8 (permalink)
FMTRVT's Avatar
My Photos: (16)
The DRWs use wider shoes and therefore longer hold down springs. Otherwise the same.
Jack
FMTRVT is offline
Old 02-09-2010, 04:56 PM   #9 (permalink)
Supporting Member
EXODUS's Avatar
Good stuff.
Thank you gentlemen.
1999 F-350 7.3 Super Duty Dually
K&N, 5" Exhaust, Edge Juice Controller
270K (so far)
EXODUS is offline
