Dinging just won't stop??? - Diesel Forum - TheDieselStop.com
Old 02-06-2010, 07:13 PM   #1 (permalink)
Zeno97F250's Avatar
My Photos: (5)
Send a message via Yahoo to Zeno97F250
I have a feeling this is an easy fix.
Everytime I get in my truck and start it up it dings at me 5 times and does it 4 times. So 20 dings. I know the truck dings if the door is open, but it isn't open, and sometimes it will start to ding while I am driving. Everything is working that I can tell?
Any ideas?
1997 Ford F250 XL 2WD SWR Reg. Cab 5 spd. (ex-work truck) Homemade cold air intake. 364K miles. SOLD
1999 Ford F250 Ext. Cab 4wd 6spd 183K Triple Gauge Pod, 7 inch single stack. SOLD
Current
1993 Ford F350 Crew Cab 4x4 Auto 336K 12Klb Winch
Zeno97F250 is offline
Old 02-06-2010, 08:05 PM   #2 (permalink)
RT
RT's Avatar
Does your open door light ever come on? It might be burnt out - that in combination with a sticking door switch would do what you are experiencing. Try spraying all your door latches with WD40 - and if the bulb doesn't come on when the door is open - you probably had the problem long enough to burn the bulb out....
If that doesn't fix it - you could always shoot your truck in the dinger....
RT is offline
Old 02-06-2010, 10:04 PM   #3 (permalink)
Supporting Member
EXODUS's Avatar
"shoot your truck in the dinger" ?
Way too funny...
1999 F-350 7.3 Super Duty Dually
K&N, 5" Exhaust, Edge Juice Controller
270K (so far)
EXODUS is offline
Old 02-06-2010, 10:10 PM   #4 (permalink)
dont mean to be an @$$ but it might be the seat belt dinger
early 1999 (4/98) f350 7.3 POWERSTROKE auto ext. cab shortbed 4x4 lariat. leveling kit with 35 12.50 R16.5 bf goodrich all terains t/a ko (toy hauler)
cwall4x4 is offline
Old 02-06-2010, 10:21 PM   #5 (permalink)
If that is the case (seat belt dinger) on my '02 I just unplugged the cable underneath the seat and it quits dinging...
RoReRi
New to me... not anymore...
02' 4x4 | F250 | CC | SB | Auto | 3.73 rear end
Running boards | Tow Mirrors | Tymar intake | DP-Tuner 80hp Eco, Stock, 60hp Tow | Fumoto drain | Sony,CDX-GT610UI | 2.5" TuffCountry leveling kit | 4" MBRP exhaust, turbo back..
96' 4x4 F250 EC 4"lift Ranch Hand Front and Rear bumpers. Tymar intake and downpipe & Cat delete pipe. 203 degree T-stat, $40 AIC, Stage 1 INJECTORS...
Running WVO since May '04
Be without fear in the face of your enemies
Be brave and upright that God may love thee
Speak the truth even if it leads to your death
Safeguard the helpless
THAT IS YOUR OATH
roreri is offline
Old 02-07-2010, 10:37 AM   #6 (permalink)
Zeno97F250's Avatar
My Photos: (5)
Okay, I think I am going to check the door switches, and make sure the door ajar light comes on. As far as the seat belt chime I always wear my seat belt and the light for that always goes out. But I will unplug that too if the door switches are all good.
IF not I will shoot my truck in the dinger!
Current
Old 02-07-2010, 02:26 PM   #7 (permalink)
spray the door latches with the miracle forumula WD 40 i had the same problem and did this and fixed it like a charm......it does wonders
1999 F-350 Dually 7.3 diesel lifted 8.5inches 37x13.50 xtream all terrains
Just Installed a DP Tuner F-5 chip, with stock, Decel, 60 Hp Tow, 80 HP econo and 120 HP performance and WOW!!! k&n airfilter Road Armor front bumber Warn 15000 winch Shift Kit, Beefier tourqe converter. Kenwood Indash Navigation, Sirius Radio, Back up camera, Kodiak Electric Steps HID Conversion Kit..
Next up is Gears!
buzzy12 is offline
Old 02-07-2010, 09:03 PM   #8 (permalink)
Zeno97F250's Avatar
My Photos: (5)
I will spray the latches tom.
The door ajar light works, and it goes out when the doors close, checked both doors. Seat belt light works and it goes out when the drivers belt is locked.
IS there anything else to look at? THat chime is only for the seat belts and doors being open?
Current
Old 02-09-2010, 01:01 PM   #9 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
That might have something to do with the airbag system.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 02-09-2010, 04:23 PM   #10 (permalink)
There is a black wire with a pink tracer under the dash that you can snip,worked
for me when I wanted to listen to the radio with the doors open and not hear
the dinging.
2000 F350 ZF6
akfalconer is offline
