Dino Oil??? Noob quest? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 02-15-2008, 09:48 AM Thread Starter
What is dino oil? (sorry, english is not my first language) From what I have read it would be a "no-name" brand oil, is it right?
2011 F-250 XLT, Crew, 6.7L . All stock for now
Sold: 1999 early F-250 XLT, 7.3L auto. with 3" Trailmaster lift, ProComp Wheels & 315/75R16 Good Year, `05 headlight conv., Autometer gauges (pyro, trans & boost), ABOC.
DP Tuner (no-start, stock, 60 tow, 80 econo, 100 performance), 4" SS MBRP, Tymar intake, 203 thermostat, frame fuel filter, Hutch & Harpoon mod, EBPV exhaust brake with TC lockup, and a $100 Stancor relay thanks to UPS...
Trail Rig :'85 Bronco II, 302, C-4, BW1350/1350, full width Spartan super 60, Lincoln 10.50, 5.38 gears, ... on 42" pitbull tires
QcPwrStroke is offline
post #2 of 7 (permalink) Old 02-15-2008, 09:51 AM
Scot06's Avatar
Non synthetic, earth made, rotten dinosaur, dinosaur poo & plant life.
06 F-350 4X4 XLT CREWCAB 6.0 w/ 285K
Odyssey batteries, FS-2500 oil filter, Dieselsite coolant filter, Line-X all over. - Original HG - Oil & egr cooler finally died at 220K
I hate when parts fail before 300K! Waterpump, well not pump, but corroded aluminum around seal caused leak.
Scot06 is offline
post #3 of 7 (permalink) Old 02-15-2008, 09:56 AM
"Dino oil" just means that it is NOT synthetic oil. It has nothing to do with brand names.
For example... Rotella T 15W-40 would be considered "dino oil" where as Rotella T Synthetic 5W-40 would not.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
post #4 of 7 (permalink) Old 02-24-2008, 01:18 PM
Amsoil by far is the best oil around for diesels, it saves money, time labor and fuel. it is the only true synthetic oil sold in the world. the others are a cracked crude that the U S allows to be sold as snythetic. if you want to researce go to the amsoil web site AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases
aknope1 is offline
post #5 of 7 (permalink) Old 02-24-2008, 02:05 PM
Jinco's Avatar
Originally Posted by aknope1 View Post
Amsoil by far is the best oil around for diesels.....
Please quantify this statement in some meaningful way.
Buy Ford. They're not taking bail-out money.
2000
F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil
, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
Jinco is offline
post #6 of 7 (permalink) Old 02-24-2008, 03:53 PM
Quit spamming. The OP asked about what dino oil is made of, not about the all mighty Amsoil.
God people like this piss me off. DIAF....
2013 F350 6.7 CCLB Lariat
ciscofreak is offline
post #7 of 7 (permalink) Old 02-25-2008, 04:43 AM
SmokeyWren's Avatar
My Photos: (45)
Originally Posted by QcPwrStroke View Post
What is dino oil?
There are two basic kinds of motor oil = dino and synthetic.
"Dino" is short for dinosaur. So in other words, dino oil is any oil made from crude oil or petroleum. It's also called "mineral" oil. The 'dino" name is based on the fact that crude oil is the leftovers from dinosaurs and other plants and animals that lived and died millions of years ago.
"Synthetic" oil is usually made from vegetable oil. Ignore the AMSoil salesman - he doesn't know what he's talking about. There are numerous brands of synthetic motor oil that are just as good as AMSoil, and they are all made from vegetable oil, so they are all synthetic. There are also some brands of oil that are semi-synthetic, i.e., a mix of dino oil and synthetic oil. And there is some controversy on the definition of "synthetic".
You can probably look it up in French. Start with the following terms:
Polyalphaolefin (PAO) = American Petroleum Institute (API) Group IV base oil
Synthetic esters, etc = API Group V base oils (non-PAO synthetics, including diesters, polyolesters, alklylated napthlenes, alkyklated benzenes, etc.)
Then there is the API Group III base oils that cause the controversy. They began life as petroleum, but have been refined to be a synthetic oil instead of a normal mineral oil.
Originally Posted by Wikipedia
Groups I and II are commonly referred to as mineral oils (or dino oils), group III is typically referred to as synthetic (except in Germany and Japan, where they must not be called synthetic) and group IV is a synthetic oil. Group V base oils are so diverse that there is no catch-all description.
The above quote was found in: Motor oil - Wikipedia, the free encyclopedia . There is probably a similar article in the French edition.
SmokeyWren is offline
