Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 11-25-2007, 07:38 PM   #1 (permalink)
dismantle front hubs 99 F350 4x4
The auto hubs stopped working on my 99, couldn't even turn the locking bar/slot on the front. So I took it apart when I was doing the brakes and used some WD40 and the hub locks and now it unlocks easy.
1)
But here is the problem, I can see there is no grease, ...nothing in the hub. The outside carrier hub gear is aluminum (a bit chintkzy I think) but there appears to be no wear. I removed the two retaining rings on the hub thinking I could disassemble the hub to clean it but I can't get the center plastic insert out to remove the inner gear. Should I just WD40 the whole mess and put back together with out any grease? Or should I take it apart and put some form of lubricant on the gears. It looks to me like it has never had any grease.
2)
I am concerned that the 4x4 vacuum pull to lock the front hub in is not working (from dash) but I don't know how to check with everything apart. Can anyone advise me and how hard is it to take the system apart (or should I) to clean it?
I think maybe the system stopped working because the front hub mechanism stopped working.
Thanks in advanc for advice. I don't have any experience with this side of the truck.
blewis999 is offline
Old 11-25-2007, 11:49 PM   #2 (permalink)
Re: dismantle front hubs 99 F350 4x4
vacum problems often show up in ac controls locking to defrost only..but mine didn't hose , my was cut on fnt axel.
have a look at guzzles's page
i think he had an article on greasing them.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 11-27-2007, 10:06 AM   #3 (permalink)
JimTJr's Avatar
My Photos: (6)
You can take them completely appart. Not sure what you cant get apart on yours, have any pictures to show where you "Stopped" at? I have had them apart all the way down to the two plastic "Cage" pieces inside. There are a couple clips in there.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 11-27-2007, 08:28 PM   #4 (permalink)
my3wags's Avatar
Try This link Lots of good info.
Good luck
Erik
Big E and family of Three
2002 F250 4X4 CREW CAB PSD 4" LIFT
4" turbo back exhaust*custom tymar*DP tunes*Polished ATS housing*6.0 intercooler*Chromed intercooler pipes*H/O chromed Alternator*Dieselsite boots*203 thermostat*40K Trucool*FTVB*Manual TC lock-up*EBPV brake*AIH delete*boost Annihilator*Custom CCV*ITP/KCM (HPX)*Coolant filter*08 diff cover*DI fuel shim kit .055 @68 psi*engine mounted fuel gauge*custom engine cover*triple gauge*((XM))
297Hp dyno 2/11/07 (I need more power Scotty!!)
Waiting for install
pre-pump mod
2004 Keystone Sprinter 297fwbhs 5th wheel
with most of the goodies
my3wags is offline
