Does Anyone Know the Wheel Offset for the F250's - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 07-15-2006, 11:28 PM Thread Starter
Guys,
Looking to find out what the difference is between the 1999-2004 and 2005-2006 trucks. All I se is that everyone says that the 05-06 wheels will not fit on ealier trucks but I don't see the offset difference.
Just curious, looking for OEM wheels for a replacement on my 2002 F250.
Brian
Brian Scigiel
1970 Mach 1 351C Stroked to 393ci
2002 Gray F250 7.3L-AFE Stage II, 275-70-18 Toyo Open Country H/T, Harley Wheels, Century Royal Cap.
mach1hauler is offline
post #2 of 13 (permalink) Old 07-16-2006, 07:51 AM
SmokeyWren's Avatar
My Photos: (45)
Re: Does Anyone Know the Wheel Offset for the F250's
Don't even think about trying to fit 2005-up SuperDuty wheels on your 2002. Life is too short.
2002 SRW wheels have 0.25" nominal offset. 2005-up SRW wheels have 1.57" inset. Someone said that offset and inset are the same thing, and that Ford simply changed the words in their specs. If that's so, then the 2005 rims will be 1.32" different backspace.
SmokeyWren is offline
post #3 of 13 (permalink) Old 09-15-2008, 11:54 AM
Trying to piggy back on the original question, and smokeywren's response, because i'm looking at the exact same option, if i ran 2" wheel spacers up front on my 02, wouldn't the 05+ 18" wheels fit just about perfect on my 02 F350 SRW? From what i can see i should get the hubcentric wheel adapters from Fred at wheeladapter.com.
2002 F350 CC LB 6spd 4x4 7.3 Tow Rig - RE 2.5" Leveling Kit, 285/75-18's Toyo A/T's, factory 05 18x8's DP-Tuner 60hp-80hp-120hp settings, 3.5" Downpipe/4" Magnaflow Exhaust & Isspro Boost/Pryo.
TJ-7 Buggy LQ4 6.0L/4L60E/StaK 3spd, 1 ton's & 40's.
wallysheata is offline
post #4 of 13 (permalink) Old 09-15-2008, 01:42 PM
SmokeyWren's Avatar
My Photos: (45)
You probably cannot find any chassis engineers that will approve use of wheel adaptors. They're simply not safe. Plus, quality wheel adaptors will cost as much as new wheels that don't need the adaptors.
TireRack.com has 18"x8" hub-centric wheels for 2004 SVT or Harley Davidson trim that will fit any '99-'04 SuperDuty SRW pickup. They say 4x2 only, but the wheels are identical except for the hub cap. $150 or $250 each, depending. If you have 4x4, then use your old hub caps with the new 18" wheels. This link says F-250, but the wheels for F-350 SRW are identical.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
On edit, over 2 years later. Link deleted as it no longer works. TireRack sold out of those wheels eons ago.
post #5 of 13 (permalink) Old 09-15-2008, 03:50 PM
Well, i scored a set of 18x8 5 star 05 Superduty wheels for $200 and ordered the 2" hubcentric steel wheel adapters for the front wheels, from Frank at wheeladapters.com for $320 delivered, which is still less than $600 plus shipping, and is the look i wanted.
post #6 of 13 (permalink) Old 09-16-2008, 10:31 AM
Originally Posted by SmokeyWren View Post
You probably cannot find any chassis engineers that will approve use of wheel adaptors. They're simply not safe. Plus, quality wheel adaptors will cost as much as new wheels that don't need the adapters.
Duallys come from the factory with spacers.
jade97 is offline
post #7 of 13 (permalink) Old 09-16-2008, 09:49 PM
Thumbs up
I put 05 five star 18" rims on my 02 250 with 2" wheel spacers and had not had any issues yet. Good Luck.
02rob is offline
post #8 of 13 (permalink) Old 09-16-2008, 11:11 PM
expertrider's Avatar
I had 2008 wheels on my 2000 f250. (Before it got destroyed in an accident)
I used the wheel spacers....they did make me a little nervous, but I carried a few 2000+ lb loads in the bed without any problems.
Don't try the wheels without the spacers, I'm pretty sure they will rub!!
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 - only for reading codes,
staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky pipe!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers (just saved my truck!)
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
expertrider is offline
post #9 of 13 (permalink) Old 09-18-2008, 12:35 AM
I've been running the 2005 wheels on my 1999 F250 and my 2004 Excursion and they ride fine but you have to tolerate rub on the leaf springs when you have the wheels cranked. It's annoying and I'd like to try the spacers but didn't realize they'd have to be 2" wide and the cost was over 300.00. I was searching the forums for info when I came across this thread. Looks like my spacer options are limited.
sage1 is offline
post #10 of 13 (permalink) Old 09-18-2008, 08:14 PM
If you do buy spacers make sure you get the ones that are hubcentric witch centers the wheel. I did not and to get rid of the shakes had to make a pice to fit in the center and it was a pain. If i would have spent the extra money up front it would have saved me lots of time.
02rob is offline
post #11 of 13 (permalink) Old 09-16-2010, 09:55 PM
Does anyone know if 2004 Harley Davidson F-250 had the same offset as other 2004 super duty 4x4? I have a 2004 Eddie Bauer 4x4 Excursion 6.0 diesel and I am looking at 2004 HD F-250 wheels 18 inch. Thanks for any help
Nightdog is offline
post #12 of 13 (permalink) Old 10-05-2010, 08:22 PM
im running the 06 style 18s on my 99 with 2 in wheel spacers and there wrapped in 35 in bfg m/ts and a 3 in leveling kit they fit perfct with no rubbing and i can turn lock to lock without hitting the leaf springs! i tried them without the spacers and they look real sucked in because of the incorrect offset and they will hit the leaf springs.
johnlx302 is offline
post #13 of 13 (permalink) Old 11-17-2010, 12:36 PM
I've had '06 wheel on my '99 for more than 3 years. The only issue I've had is rubbing on the front leaf springs when you turn sharp radius and it does cut down on your turning radius.
2006 F-250 Crew-Cab Short bed 4X4
1999 F-350 Crew-Cab, Short Bed, Auto, 4X4,
7.3 liter, straight pipe, S&B air box, DP-Tuner 80e/60t, 166k miles
Other cars:
'67 Shelby GT350, '69 Shelby GT-500
gwrandles is offline
