Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-23-2007, 09:15 PM   #1 (permalink)
DOOR LOCK PROB
HELP I have a 2000 Excursion that for 2 yr the front doorlocks only work manualy and now the system keeps blowing the fuse under the hood. Nothing has changed but the rear door locks feel hard to pull or push. Time to fix for the wife since I got a new truck, any help would be cheaper than the dealer. thanks [img]/ubbthreads/images/graemlins/shrug.gif[/img]
03 f-350 CC 4X4 Dully PSD Jody's 40\80econo\120race Autolite Cobbalt Pyro, Trans Pillar mount, AFE Stage 2 proguard7, 4" turbo back
2000 Excursion XLT SC programer, 4" turbo back
03 34' Rampage Toy Box 17000# with toys
06 4 seat Prowler Sandrail VW 2276
Misc. Quads and toys
1 GREAT WIFE 2 KIDS
sdnanney is offline
Old 01-23-2007, 10:41 PM   #2 (permalink)
Re: DOOR LOCK PROB
DO a search on door lock actuators. Its pretty common for the 99-2002 models to start having the power actuators fail. You can get oem for about $45 to 55 each, or get some universal fit for about half that. Problem with the universal ones is that you'll have to modify the mounting bracket. There are also instructions buried somewhere if you want to take yours apart and recondition them.
I took the drivers side panel loose, but I could not figure out how to disengage the actuator from the wire harness. I ended up paying a local body shop $35 to pull out the old one, replace it with the one I provided, and button everything all up. Its been fine now for 1 1/2 years.
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2003 VW Jetta TDI auto, 90k miles, all stock, no mods, 41 mpg most days. A rocket in disguise...
Repairs: alternator, brake switch (x2), power window wire harness, #4 glow plug, glow plug wire harness
On order - 2009 VW Tiguan (2.0 l turbo gas engine to take advantage of $1.79 fuel prices [for now])- should arrive off the boat soon.
short_stuff is offline
Old 01-24-2007, 12:00 AM   #3 (permalink)
Supporting Member
Re: DOOR LOCK PROB
I just replaced the rear passenger actuator. I bought mine from the the dealer, but next time I will buy from Ebay ... Actuator on Ebay. Appears to be OEM.
It took me a couple of hours to remove it and only ten minutes to pop the new one in.
All you need to do is remove the door panel and then remove the door handle. Once the door handle is out you can remove the actuator. This was not obvious until I removed the whole lock.
PM me if you need help.
Best Regards,
Moxie (from 1828 Noah Webster Dictionary) : The ability to face difficulty with spirit.
2K F350 DRW Lariat 6spd CC White/tan 7.3L, 226k miles, 4" Magnaflow, CCV, SP Diesel, DP-F5, AIH delete, fuel @ 65psi, DIY Tymar 6637 Filter, Fumoto, MAP sensor reg. (fooler)
2K Excursion Ltd Burg 7.3L Auto, 130k miles, 2x4, HX, FX, Fumoto, fuel (66psi), Roof rack delete, DIY Tymar w/ 6637 Filter, AIH Delete, 100HP Diablosport
Late 98 (04/98), 7.3L WHT F250 Std Cab 2x4, 6 spd, Southbend Kevlar bushing, 298k miles, Tank, CCV, HX, FX, Coolant Filter, DynoMax, Shimmed return (67psi)
$$$ Penny glow plugs at AutoZone
Pics
moxyspirit is offline
Old 01-25-2007, 09:49 PM   #4 (permalink)
Re: DOOR LOCK PROB
Re: the ebay actuators---There is one company selling MANY actuators there. I ordered two and they BOTH failed within weeks. It took me several months of emailing to get them to send replacements but they only sent back ONE and asked me to send both badones back to them. Im still in that debate. They are not as sturdy as stock. Its a PITA to have to keep re-doing them so Im just going to Ford and pay more.
2001 F-350 Lariat,CC,LB,SRW,4X4,Auto,7.3,2"lift,KYBs, 285x75x16 ProComp AT's, 3.73, steel oil x-over, aFe Stage II Pro 7, AirCond mod, Fumoto, DP 60,80,100. AIH Delete, hi-lite/fog-lite on mod.
My truck http://www.iwantamortgage.com/pics/id4.html
MarvinVR is offline
Old 01-25-2007, 10:07 PM   #5 (permalink)
Re: DOOR LOCK PROB
there was a post here not long ago about how to fix them for free,,naybe someone has the link
2001 7.3. Lariat...
muffler delete,Isspro guages,AIS,SCMT 1705,CCV Mod,Zoodad Mod
Lone20 is offline
Old 01-26-2007, 08:48 AM   #6 (permalink)
Supporting Member
Re: DOOR LOCK PROB
Or get them at Fordparts.com
Best Regards,
Pics
Old 01-26-2007, 02:49 PM   #7 (permalink)
NCHornet's Avatar
Re: DOOR LOCK PROB
If he is blowing the fuse, the problem is not in the actuators, this doesn't mean they aren't bad, but he has a short somewhere. Time to start tracing wires. I have a write up on the replacement of the actuators if you need it. Only use the Ford units, the new ones are much stronger.
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 04-14-2007, 07:16 PM   #8 (permalink)
Re: DOOR LOCK PROB
Finaly had the time and found a wire rubbing the window track in the pass. door. Taped it up and all is fine. Thanks for the help
1 GREAT WIFE 2 KIDS
sdnanney is offline
