1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
When my driver's side door is open and no key in the ignition, I still get a door chime. I assume this isn't the intended functionality? Is there an easy fix?
I saw the posts about removing the piece of metal from the ignition cylinder, and I checked that out, but everything looked normal and the problem didn't change. I just bought the truck used, but it's still under warranty. However, if it's an easy fix, I'd rather not waste the time taking it to the dealer for something simple that I can fix.
That isn't normal unless you have left the parking lights or head lights on. It should not "ding" if there is no key in the ignition unless as stated some lights are left on.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
2001 F-350, Super Duty, Dually, LWB, Lariat, 7.3 PSD, Crew Cab, 4.10 LS, Auto Trans., Husky Wood Grain Dash, 6.5" Pro Comp Lift, 315/75/16 Toyo MT's, Dual Front Shocks, Air Bags, Bill's 4 position Chip, AFE, Stull Billet Grill, Western Diesel A-Pillar 3 Gauge Set, 3.5" to 4" Pinnacle with Magnaflow, Redline Synthetics in motor and transmission, Banks Turbo Wheel,..... MY PICS!
2011 F250 CC XLT Short Bed 6.2L
2005 F350 Lariat Crew Cab Long Bed ,MBRP 4" Off Road Exhaust,20" Ford Harley wheels with BFG AT,Bilsteins,Zoodad mod,Acufab Power Elbow (TRADED)
2005 Harley F350 Crew Cab Long Bed (SOLD)
2002 Excursion Diesel limited 4X4 V Code Front springs,F350 Rear Blocks,AFE Stg2 ProGuard7,MagnaFlow XL Exhaust 3.5DP, Helwig Swaybar, Bilstines F&R,285-70-16 BFG KOs on Stock F250 Rims (SOLD)
1999 E250 Work Van (CLUNKERED) http://community.webshots.com/user/thetiler
If you bump the steering wheel with your hand it will usualy quit dinging... The little button inside the key slot is sticking and i cant find a way to fix it.... I have lubed it and anything else you can think of....
2003 F350 DRW 4X4 Lariat 6.0L
2002 F350 SRW 4X4 Lariat 7.3L
1998 Lincoln
1997 Dakota 4X4 SOLD
1996 Ranger
1986 Corvette Caught Fire IN Garage
17' Bass Tracker
2003 Montana BigSky 5th Wheel 3 slides
A little squirt of WD 40 in the key slot and work the key in and out about a dozen times and squirt one more shot and work the key several more times and you should be golden, good luck ,Larry
'04 6.0 F-350 Red, Lariat, CC SB 4x4,power roof & rear slider,K&N ,285-75-16 BFG muds on polished EX wheels, 08 alum. diff cover, SnoPatrol package
