Dry weight of F250 4x4 PSD? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-19-2007, 10:49 PM Thread Starter
Muddinf2501999's Avatar
Hey guys, I was just curious if anyone knows the "dry" weight of an extended cab, 4x4 PSD Super Duty. I know it shows the GVWR on the door etc. Im looking for the actual truck's weight though..
Thanks guys!!
'99, 7.3L PSD F250 4x4 SRW
Mods: BTS Tranny!!!!, Rockwell 2 1/2 ton axles, Goodyear MVT 395/85R20's and Schaeffer's Oil
'02, 7.3L PSD 6spd F350 4x4 DRW CC
Mods: IH Bellowed Up-pipes, 4" MBRP Turbo Back Exh, B&W Gooseneck Hitch, Michelin LTX A/T2 235/85R16's and Schaeffer's Oil
Muddinf2501999 is offline
post #2 of 12 (permalink) Old 06-19-2007, 11:21 PM
Re: Dry weight of F250 4x4 PSD?
I do not have the info for your particular year handy, but I would say that it weighs in the 6500-7000 lb. range.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
post #3 of 12 (permalink) Old 06-20-2007, 12:35 AM
My Photos: (5)
With 46" tires and Rockwell's......... you're over 8K lbs.
My truck tipped the scales at 7960 with me in the driver's seat, and just under half a tank of diesel. Oh, and that was without the fiberglass bed cover. That sucker is easily 200 lbs.
Pocket is offline
post #4 of 12 (permalink) Old 06-20-2007, 12:46 AM
Mine stock, me the truck 1/2 tank, 150lb tool box, 7320lbs.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #5 of 12 (permalink) Old 06-20-2007, 01:12 AM
andrewbalser's Avatar
I have the supercab, short bed 4x4, 6.0 250. With a spray-in liner, full of fuel, and no tool box yet, it grossed 7700. So take about 375 lbs off of that for the driver and passenger in this case, and you're left with 7325 approx. Also, if you look at the engine specs the 6.0 is real close, but slightly over the weight of the 7.3 engine. So a 7.3, ext cab 4x4, short bed could easily weigh ironically... right around 7300 lbs.
[img]/ubbthreads/images/graemlins/cool.gif[/img]
andrewbalser is offline
post #6 of 12 (permalink) Old 06-20-2007, 01:27 AM
Mine was 6820 if I recall correctly with a full tank and just me. Thats a SB so its only 29 gallons of fuel.
03 7.3 EXT. cab 4x4 Powered by No Limit Diesel Performance, Trucks By Buck. DIY Tymar, IDMed, 5" Hypermax 3.5"DP, Autometer gauges, DP Tuner 6 pos. stock/40/80/100/140/High Idle, heater plug delete, BTS Valve Body a must for those of you who cant afford a BTS tranny yet, WW, and the Zoodad MOD.
milskired is offline
post #7 of 12 (permalink) Old 06-20-2007, 02:30 AM
Dang, My truck tipped the scales at 8800lbs, empty bed with 3/4 tank of fuel and my fat butt. I want a lighter truck to turn faster ET's and be able to enter more truck pulls(they are limited to 8K).
Keep Strokin'
: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
strokin_early_99 is offline
post #8 of 12 (permalink) Old 06-20-2007, 03:15 AM
klhansen's Avatar
My Photos: (180)
My truck weighs right at 7400 lb IIRC with me and my normal junk on board. Stock tires, and long bed with a tow strap and a set of chains in the back.
I've got it written down somewhere around here.....
), AIS,
regulated return,
klhansen is offline
post #9 of 12 (permalink) Old 06-20-2007, 10:41 AM
7640 with me and a tool box in it
2003 Lariat 6.0 Arizona Beige/Med Parchment Crew Cab 4wd Auto 3.73 born on 5/9/03
bedwards is offline
post #10 of 12 (permalink) Old 06-20-2007, 10:51 AM
imelmo's Avatar
Look here: http://forums.thedieselstop.com/ubbthrea...e=0#Post3387719
2002 F-250 Lariat 4x4 crew-cab short-bed automatic, lots of stuff from DI Performance (Diesel Innovations)713/984-9441, Terminator hpop, ATS trans, and some good help from Chris Pitre at Pitre Automotive of Lafayette, LA 337/945-8049 (and a few other great sponsors) pm me for any details; Best time on 37's = 13.09 @ 102mph, #2 only;12.18 @ 111.71mph on Da Juice
Current Project: '86 Toyota regular cab, full tube chassis, fully built 7.3 Diesel Innovations Powerstroke engine and Terminator hpos
imelmo is offline
post #11 of 12 (permalink) Old 06-20-2007, 01:26 PM
I am at 7350lbs with grill guard and winch that is around 150 to 200 lbs.
02 F250 4X4 Ext. Cab with 238K 4" Procomp Stage II lift, Banks turbo housing, 4" Exhaust W/single 5"stack, Microtuner, Harpooned fuel tank, and a lead foot!!
noall8ball is offline
post #12 of 12 (permalink) Old 06-21-2007, 05:38 PM Thread Starter
Thanks for all the info guys!!
I was curious to know the rough number for stock weight to figure out how much I have added. I ran it across a scales last week and it weighs 9,000lbs with an EMPTY tank!! lol My tire / wheel combo weighs 292lbs each.
Anyway, thanks again guys!!
