1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
I've been having a problem with my driver's side window sticking (stops working). There does not seem to be any problem with any of my other three electric windows - I use them all the time with zero problems.
How can I check to find out if the problem is with the switch or the motor (actuator?)? If I put the window down I can 'play' with the switch and it will go back up but I've been stuck a few times and had to leave the window down (didn't have time to keep 'playing' with the window switch). The motor (actuator) does not sound like it's making any noises and the speed of the up/down seems to be normal (on the rare occasion I can get it to work).
Help!?!?!?!
2002 F350 7.3 CC 4X4 Lariat w/ Auto tranny, 4" Diamond Eye Turbo-Back, Tymar Performance Intake by Dale, 3 gauge A-Pilar with Autometer Gauges (pyro, trans, boost), 18K mod, Dual relief valve, AIH Plug, Boost Tube, Sonnax/Tricumulator
I think the drivers side window also has a seperate relay for the express down feature, could be your problem, I think it is located on the fuse panel inside the cab.
my 01 has the same problem the pinch molding is the hold up when its wet it works fine and i have tried all types of stuff and nothing seams to work for long
but lubed up man watch out it moves fast
2001 F-350 larait c.c. s.b. 4x4 auto, keenwoodkvt915 in dash dvd 7inch screen ,1 alpine Rtype 12 woofer 1500 watts,pheniox gold mono block class d amp, scorpion BOX, level kit,mr taillight foglight highbeam kit, stock ford 18's on contie's, rancho 9000ES shocks ,6.0 transcooler, derale trans pan ,ccvdiy mod ,zoo dad , powerstrokehelp.com FUEL mods , hood insulation delete ,foil delete , high presure oil x pipe, DP tuner F-6 = 900rpmEBV, drive-thru tune ,EBV Engine brake tune,40tow ,60 econo, 80econo , supersmoke (use with OD) , 100hp, 120race 140agrresive, 3 pilier pod , pyrometer, 2trans temps inside tranny/outside ,boost,diy cold air6637 & 45 degree 4 inch alum.8"x8" , JEG'S 4" downpipe to 5" exhaust flopro 6"tip , dfuserA.I.H.plug, Extreme diesel Xwheel , (commin soon banks technicooler )
i replaced my driver side window motor last night after fiddling with it just as you have done. i agree with the other two comments- there is a relay #4 for my '99 inside the cab and typically 30 amp circuit breaker in engine compartment. when replacing i noticed that there was not any grease on teeth of window regulator- i corrected that and also lubed the replacement motor's gear ( Cardone). put it all back together and window did not move. relay clicked and i replaced with one in stock. window moved 2 inches. removed circuit breaker and replaced with 30 amp fuse. window took off - cycled up and down numerous times. put existing relay back in. everything still good. took out 30 amp fuse and installed existing 30 amp circuit breaker. window up and down but a bit slower, hard to tell not going to time it either. i think that these windows get jambed up just as other person noted. i was planning on sliming the rails with a silicone product as i did the door weatherstripping. i did not test the original motor, could not turn gear when it was out, but i think that these regulators need to be greased well, windows can't stick in the guides- difficult in winter and patience exercised so as to not break the windows when stuck.
This is an OLD post that I started but I thought I report my conclusion. I finally pulled the door multi-switch out and started 'hot-wiring' posts till I figured out what electrical connector (on the switch) made the windows go up and down. I isolated the drivers side window for 'up' and 'down' and had no problem getting it to go down but I had to bypass the switch to get it back up. So...I 'hot-wired' the window up...broke off the post that controls the window down (so I don't accidentally put it down) and now I need to order a new multi-switch...clearly the switch was bad.
