Originally Posted by Kanman
I would start looking for a shorted wire somewhere. Check everything that is shared with the #8 fuse.
I'd agree. Start by pulling the fuse and connect an ohmmeter between the output terminal of the fuse and ground. Turn the headlight switch to park and see if the meter indicates a short. If so, start pulling bulbs and check the with meter each bulb. If that doesn't make the meter read something other than a short, then it's in the wiring itself. Might be just a shorted bulb - weirder things have happened.
Good luck
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
