Electrical Issues - Page 2 - Diesel Forum - TheDieselStop.com
Old 03-31-2009, 06:08 PM   #16 (permalink)
bugman's Avatar
My Photos: (18)
Originally Posted by jposes View Post
Is there a particular type of relay for this application? Also can I find them at any autoparts store?
You should be able to find a driving light install kit that has the relay, fuse, and a switch at any auto parts store. When you wire it in you can go either with a switch to control the relay or just use your park lights to control it. Also if there isn't a fuse you should wire in a fuse from the battery just in case the wires short our somewhere.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 03-31-2009, 10:14 PM   #17 (permalink)
klhansen's Avatar
My Photos: (169)
Here's some parts suggestions:
FIVE TERMINALS, BRACKET MOUNT RELAY STANDARD STANDARD 40 AMP RELAY AUTOMOTIVE RELAYS RELAYS AND SOLENOIDS* - Waytek Wire
5 PIN HIGH CAPACITY/STD RELAY CONNECTOR RELAY CONNECTORS AUTOMOTIVE RELAYS RELAYS AND SOLENOIDS* - Waytek Wire
FUSE HOLDER FOR MINI FUSE MINI FUSE HOLDER BLADE FUSES CIRCUIT PROTECTION* - Waytek Wire
You should be able to find similar items locally, or other online shops as well.
Hard or no-start? Check Here
klhansen is offline
Old 04-01-2009, 01:36 AM   #18 (permalink)
jposes's Avatar
Ok so now I know what I need. Thanks for the replys. Can someone explain what exactly the relay does and how I will need to wire it in. can I wire it inline somewhere or does it need to go in the fuse box with the others? Right now the lights that are giving me problems are the capsule shaped ones in my headache rack that have two hots running to them. One for the brakes/signals and the other for the running or parking lights. The brake and signal lights still work fine but I disconnected the other wire because it was causing my #17 fuse to blow. I replaced both whole units since you cant remove the bulbs thinking that would solve my problem but it didnt.
Black 2002 F350 XLT 4x4 Crew Cab 7.3L (build date 11-01) - Goodyear Wrangler Duratrac 325/65/R18 mounted on KMC XD Monster 18x9 Wheels, 4 inch ProComp Lift w/ dual front shocks, Ranch Hand-Full replacement front/rear bumpers, Leer Camper Shell Autometer Triple guage pillar pod with Autometer Sport Comp Pyro and boost gages, Autometer Ultra lite digital Trans temp gage, DP Tuner (60hp econo, 60hp tow, 100 hp performance) w/ in dash mounted ex switcher, AIS, Bosch Alternator, Viper 3000 alarm, NFab Nerf bars
Cosmetic upgrades: 2010 Tailgate, 2011 power folding/telescoping towing mirrors,
In the works: 2009 FX4 door panels with OEM switches, OEM backup camera and LCD rear view mirror, OEM Overhead console
jposes is offline
Old 04-01-2009, 10:34 PM   #19 (permalink)
klhansen's Avatar
My Photos: (169)
You can mount the relay just about anywhere you want. But it probably won't fit in the fuse box with the others unless you plan on doing some fancy mods to the fuse box.
If you pull one of the relays in your fuse box, you'll find a diagram on them that shows how they work. The control terminals are what you'd wire between the switched power source and a ground. Then wire from the battery (thru a fuse) to the common switched terminal, and from either the normally closed or normally open switched terminal to your load. When the relay is activated, it changes the state, connecting the normally open terminal to common and disconnecting the normally closed terminal from common.
Here's a diagram of how I did auxiliary backup lights.
Wiring Diagram for Aux Backup Lamps - TheDieselStop.Com Photo Hosting
klhansen is offline
