emergency brake adjustment - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 04-12-2007, 02:51 PM Thread Starter
smkrny203's Avatar
Greetings,
I may be dumb as a rock but I cannot find a way to adjust my e-brake on my 2000 F350 DRW. It will not hold the truck on a hill [img]/ubbthreads/images/graemlins/eek.gif[/img]. Is it adjustable somewhere or do I possibly need new pads or something else?? Any help appreciated!!
2000 WHITE F350 CC DUALLY 4x4, TYMAR INTAKE, AUTO METER PILLAR GAUGES (EGT, BOOST, TRANS), MBRP 4" TURBO BACK EXHAUST, WICKED WHEEL, DP TUNER 80 ECONO PCM BURN
, BTS VALVE BODY
, MODDED 2005 GRILLE AND 02-04 HEADLIGHTS/ CLEAR PARKING LIGHTS
2005 BLUE EDDIE BAUER EXCURSION 4X4 6.0 AUTO 285/75/16E BFG ALL TERRAIN KO'S-OTHERWISE STOCK FOR NOW
smkrny203 is offline
post #2 of 3 (permalink) Old 04-12-2007, 03:34 PM
LOOSEWHEEL's Avatar
Re: emergency brake adjustment
Just did mine last night. I have a SRW but it should be the same. If not, someone will chime in. On the rear backing plate, there is an access hole covered by a rubber plug about an inch long. Remove the plug and adjust the star wheel a tooth or two. Adjust by inserting a blade screw driver and force one of the star teeth downward.
2001 F350 CC SWB 6spd WHITE 8.5" on 37's. Currently getting a complete makeover......stay tuned.
'Everything is possible if you don't know what you are talking about'
LOOSEWHEEL is offline
post #3 of 3 (permalink) Old 04-12-2007, 04:14 PM Thread Starter
smkrny203's Avatar
guess I should have seen that...thanks much!
, BTS VALVE BODY
