General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Just bought a brand new 2006 Last Night, so I need to give the 2002's Engine a bath. Any recommended procedures for this, I was planning on going the the self-serve wash to clean the engine. Are there any areas of the engine that should not get excessively wet? Engine cool or hot? I would assume cool but........ Let me know what any of you have done.
I do it at home with a garden hose personally. Too much pressure at the self-serve. Go get some engine de-greaser, and apply it to a cool engine, and let it soak for a while, then just use a garden hose with a mild sprayer on it. No need for the 1000psi pressure to get into everything. Looks great afterwards. To really spruce it up, get the armor all and spray the hoses, etc afterwards.
NO Pressure washer!!! I use simple green or the purple stuff as the degreaser smells to bad for a week afterward. I do this on a warm day, cover the alt and the Power steering cap, it has a hole in it, let the degreaser sit 10-15 min then hit it with garden hose and leave the hood open to dry for several hours before starting. Auto zone sells a product called Engine Detailer and it really make the engine bay look good without the stickiness.
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
I personally like the power washer, but you have to be careful. If you do use a powerwasher, use a wide stream from 2-3 feet away and you will be fine. Just make sure to cover as many connections as possible with plastic. I use GUNK Citrus and the smell is better than standard GUNK after you start it up.
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains *No Lift-See Pics Below*
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank ::click, click, drive away::
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
Mods Very Soon to Come:
HID Lights
Code 3 Lightbar/Highway Strobes
Rear Reciever Mount Winch
AVIC-Z2 In-Dash Navigation Sytem
Nathan K5LA 5 Bell Train Horn
Road Armor Rear and Front Bumpers
The power steering fluid reservoir cap has a vent hole so cover that up. Other than that I just try not to spray a direct stream on anything electrical. Be sure to do this on a cold engine so there won't be any thermal shock on hot manifolds, ect. I also start the engine immediately after washing it and either drive the truck or idle it long enough to reach operating temperature. This dries things out quicker and you can see right away if you messed up anything with the water.
This engine washing thing is really important to me. you should do this regularly; about every other time you wash the truck you should also wash the engine. If you stay ahead of the dirt it will clean up much easier and more completely. I usually never have any problem selling any of my vehicles after I pop open the hood and let the prospective buyer see how clean things are under there. Good luck.
2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, adjustable pedals, reverse sensor, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
2008 Big Horn fifth wheel by Heartland RV model 3670RL. 38' long, 4 slides and all the goodies.
