Exhaust Back Pressure Valve - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 01-17-2007, 05:14 PM Thread Starter
Is it normal for the Exhaust Back Pressure Valve to operate once I start driving the truck (after it's been warming up for 10 min.)? I could still hear the hissing this morning as I was driving to work, but it seemd to stop halfway there. I also noticed it when I went out at lunch today. It was 13deg this morning and probably low 20's at lunchtime.
This might be a very basic question, but it's my first winter with a diesel and I just want to make sure that all the different sounds I'm hearing are normal.
Thanks all,
Peter
2002 F350 Superduty 7.3 PSD 4X4 Crew Cab Longbed
F350Peter is offline
post #2 of 10 (permalink) Old 01-17-2007, 05:46 PM
Re: Exhaust Back Pressure Valve
hey pete everything sounds normal to me.. if you had straight exhaust you'd want to unplug it for sure.. mine was singing this am too. here in westport it was 11' this morning
early 99 F250 cc 4x4 auto.. gages on the pillar, tymar intake, 5" MBRP exhaust, dp tunner 60,80,120, 30 gallon gravity feed aux. fuel tank, putco chrome on all handles and mirrors, GOS racing headlight harness, clear headlight and corners, accetone badges, blue ovals pelled, zoodad mod
paytontag is offline
post #3 of 10 (permalink) Old 01-17-2007, 06:31 PM Thread Starter
Hey tags37, I'm in Somerset. I work in Dartmouth and I was probably close to Westport by the time it started to sound normal. What do you mean by unplugging it? I don't have factory exhaust, and when it sings, it's wicked loud!
post #4 of 10 (permalink) Old 01-17-2007, 06:44 PM
ritschner's Avatar
Send a message via AIM to ritschner
The exhaust back pressure valve is triggered by oil temperature. If the oil temp is below about fifty degrees the valve will close during light throttle. You can split one of the wires and splice in a switch, which will allow you to manually overide and allow the valve to open. It will set a code but no check engine light. I did this on my early 99, I would run it about two miles on a twelve mile morning commute and then switch the valve open. It recovered the two MPG I lost during cold weather driving.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Bilsteins, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB, Accufab elbow, Edge Attitude CS, Blue Spring Mod, DCPower 185a alternator, Rebuilt FICM, STC and Standpipe update, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
post #5 of 10 (permalink) Old 01-17-2007, 07:06 PM
pete.. the plug is at the base of the turbo housing its the only plug down there but is a little hard to find..
post #6 of 10 (permalink) Old 01-17-2007, 07:52 PM
468LC's Avatar
I unplugged mine at the sensor on the front of the motor to get it to stop hissing NON stop in below freezing temps. Above freezing it seems to be normal but when below the damn thing was on literally all the time.
Does it matter which one you unhook? The sensor or the connector back by the valve itself?
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 100k miles.
Wix coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT. Sinister EGR delete, EGR cooler delete, up pipe. Looney Tune via SCT X4. S&B Intake.
Mag-Hytec transmission pan, 08 diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
2012 Heartland 5th wheel. 36' @ 12k pounds.
468LC is offline
post #7 of 10 (permalink) Old 01-17-2007, 08:14 PM
not thinking so.. i believe that some were getting ses lights on when the front plug was unpluged
does your truck still go to high idle when its cold?
post #8 of 10 (permalink) Old 01-17-2007, 08:36 PM
468LC's Avatar
I ran the thing with a dead sensor for 3 years and never had the SES light on. All it did was store a code in the computer.
Yes it still goes to high idle when it is cold out.
Steve
468LC is offline
post #9 of 10 (permalink) Old 01-17-2007, 08:48 PM
still goes to high idle.. cool i'm unpluging mine tomorrow. i wasnt sure if it would still kick up with it unpluged.
post #10 of 10 (permalink) Old 01-17-2007, 08:53 PM Thread Starter
Where is the sensor on the front of the motor? Think I might give it a try tomorrow too.....
468LC, how did the new 05/6 front end install? Is it a simple bolt-on procedure? I love the new grills, yours looks great.
