Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-20-2008, 04:47 PM   #1 (permalink)
rednecksteel's Avatar
Exterior mirror mount
Hi all, a couple weeks ago i was backing my truck up at night and broke my passenger side mirror off of the door. The aluminum triangle peice (don't know what else to call it) that the plastic mirror sits on is broke in a couple spots as well. I just got off the phone with the dealership and they said i need to buy a new door, is that true? When i was looking at it, i pulled a couple grommets out on the inside of the door (when the door was open) and found some nuts that i could get at with a socket and assumed that was how the aluminum triangle piece was held on to the door. Any help is appreciated.
2006 F-350 Lariat C/C S/B, 6.0 PSD, BFG A/T's, Sirius sat radio, 4" turbo back Diamond Eye exhaust (nice whistle) Diprico EGT, Tranny and boost gauges, 08 mirrors. Road Armor bumper on order and Warn 16.5 winch sitting in shop.
rednecksteel is offline
Old 08-20-2008, 04:57 PM   #2 (permalink)
BLOWINSMOKE99STROKE's Avatar
there should be 4 grommets with nuts in there when you take them off. if you remove the nuts you should be able to take off any remnants of the mirror. then slap on a new one. (Advance auto can get them much cheaper than the stealership) if the nuts got ripped right out of the door, and you can not mount the new nuts in that location, then you will need a new door.
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, "THROTTLE BODY SPACER" (ACTUALLY JUST AN INSERT IN THE INTERCOOLER LINE TO ROTATE THE AIR, probably doesnt even really work). BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, BUG GUARD AND WINDOW VISORS. 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS.
SOON TO COME: 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
BLOWINSMOKE99STROKE is offline
Old 08-20-2008, 05:07 PM   #3 (permalink)
Thanks, that's what i thought. So the new mirrors should come with the aluminum piece that actually bolts into the door? I'm going to try it in the next few days and post my results.
Old 08-20-2008, 05:09 PM   #4 (permalink)
yes, mine came with it. it was attached to the mirror, and had the studs coming off to be mounted into the door.
Old 08-20-2008, 07:44 PM   #5 (permalink)
Supporting Member
my03psd's Avatar
When you buy a mirror it is a direct bolt on.Like BLOWINSMOKE said unless the nuts ripped through the door you will have no problems,even if they did there's ways around replacing the door.But I doubt that's the case.I work at a collision center and even w/ mirrors ripped off from accidents they never rip through the door,the studs usually break off first.Good luck.
03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,tint,Rhino lined,Sirius,Roll&Lock,strobes,Flaspaq,Prodigy brake controller, HFCM plug upgrade,& Energy Suspension bushings
my03psd is offline
Old 08-26-2008, 11:22 PM   #6 (permalink)
Thanks guys, will post results when i get done (month or so) Don't think i'll run into any problems now though.
Happy trails
Old 08-27-2008, 09:35 PM   #7 (permalink)
I just did the same thing today. None of the black plastic broke and it all functions well (folds in and out and retracts and extends. My problems are the motors that move the mirror dont work. the only side that works is to move the mirror down. the mirror glass and the plastic were popped off the center nut and guide pins so it was hanging by the motor boots. Is there a way to take apart the mirror and get new motors?
2001 F-350 CC ZF-6 DRW 4x4 4.10, 15k lb modified J&I flatbed dump, DP tuner F-5 chip: No Start, Valet, High Idle,Stock, 40 Tow, 80 Tow, 80 Econ, Smoke, Lope Idle, South Bend Con OFE, Midwest short shifter, Ranch Hand legend front, Ford AIS intake with zoo-dad, 4 inch turbo back straightpipe, Pacbrake exhaust brake, 2WD Low mod, ISSPRO pyro, boost, water temp A-Pillar, Optima yellow tops, Custom gooseneck/conventional hitches, 255/85/R16 BFG mud terrains, Galaxy 979 CB, Bearcat 350 scanner, Eagle eye off road and cargo lights 900 watts total, Durabak brush guard on wheels and door panels, Prodigy brake controller, Timbren rear blocks, 4 leaf overload pack, Onboard air with horn, Phenoix underbody boxs, Royal Purple in the running gear, Dieselsite 203* t-stat, ESOF lines, DIY HX mod, CCV to atmosphere, Fumoto Valve, Deletes: HI, IC foil, Door dinger, Muffler,
fire57dan is offline
Old 08-30-2008, 08:06 AM   #8 (permalink)
my truck had the same problem, i wound up just replaceing the whole mirror, everything i tried to fix it wouldn't work. maybe someone else has a trick, but i couldn't find one.
Old 09-02-2008, 01:41 PM   #9 (permalink)
OE Ford mirrors are cheaper than advanced at least here. Adv wanted 226 each for my truck and were exactly as OEM, new from Ford were 167 and 176 apiece(L&R) and they have a new feature, they will rotate forward as well as backward without destroying the door. They are also the elec. telescoping version and I am working on setting up switching to use this option. I had electrically operated mirror heads.
P.S. the new ones also have adjustable spot mirrors unlike the fixed OE units from stock.
ddm502001 is offline
Old 09-02-2008, 07:46 PM   #10 (permalink)
WOW... I GOT MINE FROM advance and they were 160 each...
