Flashing Over Drive Off light on gear shifter 2000 F-350 - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-12-2007, 11:09 PM Thread Starter
Happened 1 time, shut the truck off and re-started it and it didn`t return. When it was flashing the truck drove fine. Does this mean I have a fault code stored?
2000 F350 4 X 4 non-DRW....DP tuner 4 pos. program, AFE stage II, BTM muffler, wicked wheel, EBPV delete housing and pedalstal
XFACTOR is offline
post #2 of 7 (permalink) Old 11-12-2007, 11:17 PM
Cool_Canuck's Avatar
My Photos: (12)
Re: Flashing Over Drive Off light on gear shifter 2000 F-350
Yep, but it's a tranny code and might need a high end reader to get it.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/
; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED;
Cool_Canuck is offline
post #3 of 7 (permalink) Old 11-13-2007, 08:51 AM
It is trans related. Take it into any tranny shop that offers free trans check and they will drive the truck and run a diagnostic. That is what I did when mine was flashing and turned out it was a VSS code. Took it home and replaced the sensor and been fine ever since.
2005 F-250 XLT 4X4 V-10
2006 Wildcat 31QBH Fifth Wheel
imsailor is offline
post #4 of 7 (permalink) Old 11-13-2007, 01:53 PM
losfinch's Avatar
IIRC weren't some guys saying this is what happens when the OD wire is shorting out up inside of the gear selector lever? Seems like some were fixing this on their own? [img]/forums/images/%%GRAEMLIN_URL%%/confused.gif[/img]
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #5 of 7 (permalink) Old 11-13-2007, 06:01 PM
I think when the wire shorts, it blows a fuse,,,,
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #6 of 7 (permalink) Old 11-13-2007, 11:02 PM Thread Starter
sometimes when I pull the lever (the slack play it has) I can get the OD light to flicker, wonder if it is a bad wire. It hasn`t done it since that one time
XFACTOR is offline
post #7 of 7 (permalink) Old 11-14-2007, 09:11 AM
My Photos: (10)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: XFACTOR</div><div class="ubbcode-body">sometimes when I pull the lever (the slack play it has) I can get the OD light to flicker, wonder if it is a bad wire. It hasn`t done it since that one time </div></div>
Yes check column wires.
Bill
MADVAN is offline
