Fog light bulb replacement - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 06-27-2007, 02:05 AM Thread Starter
How do you get the burnout bulb out?
2003 f350 Crew Cab Long Box fx4, 6.0L diesel with 150 000 KMS. No mods.
300rwhp is offline
post #2 of 5 (permalink) Old 06-27-2007, 05:13 AM
GAZ4x4's Avatar
My Photos: (17)
Re: Fog light bulb replacement
I just remove my front license plate, then I can get my arm in to reach the back of the foglights to twist and pull the socket out.
2005 F-250 CC/SB 4X4, 6.0L PSD-Torqueshift
med wedgewood blue,towcommand,upfitter switches
5"procomp lift with 5" Donahoe shocks and rear springs, 35"tires, 4.30 gears
BCP mod, LED taillights, 4"Banks exhaust, Harpooned fuel tank,
Accufab intake elbow, ARP Headstuds
Pioneer avic-D3 with backup cams and ipod
GAZ4x4 is offline
post #3 of 5 (permalink) Old 06-27-2007, 07:33 AM
haul_n_horses2's Avatar
My Photos: (17)
Remove the grille by taking out the 4 screws at the top and the spring catches at the bottom. That leaves a huge space behind the bumper to reach through. Turn the lamp socket and it will come right out. Lots faster this way and you won't mess up the bulbs.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #4 of 5 (permalink) Old 06-27-2007, 11:57 AM Thread Starter
So just to be clear do i need to turn the bulb or is their a locking ring i need to turn before i can remove the bulb?
300rwhp is offline
post #5 of 5 (permalink) Old 06-27-2007, 01:07 PM
My Photos: (17)
Turn the whole mount. No locking ring like on the headlamps.
