Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 11-08-2009, 07:29 PM   #1 (permalink)
Fog light relay on 02 f350
Anyone know where its located? None of the relays in the drivers side fuse panel are for fogs. Atleast the book says no. The are a few relays under the hood on drivers side near master cylinder that I have no idea what they are for. My fogs quit on me. No juice at end where plug connects to fogs,switch is good, fuse is good,I assume there is a relay bad somewhere and its impossible to follow the fog wire through engine compartment.
Rob-2002 f350 crew cab w/82000 miles..4 inch mbrp xl series stainless steel exhaust,S & B cold air intake,bilstein shocks,skyjacker dual stabilizer,285/75/16 firestone destination a/t,2.5 inch hanger/shackle leveling kit,disellite a/c cold mod.,back up camera,Pillar isspro guages pyro,tranny,boost,OBA, DP Tuner(80E no codes,no start,drive thru),foil delete,CCV mod,JW valve body,wicked wheel,08 aluminum rear diff cover coming soon and then who knows but something!!!
rtazz17 is offline
