The FOG .......................lights - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-09-2006, 01:03 PM   #16 (permalink)
doczenith1's Avatar
My Photos: (11)
Re: The FOG .......................lights
Select Parking Lights and pull out the fog light switch. Your fogs will be on and your headlights will be off. Works every time on both my 2003 and 2005 X.
RoyC
That DOES NOT work in my 02, although I wish it did.
I think what the original poster is referring to is the Steve Racer mod.
PM me and I can supply you with a link to another site. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Works on my '02!
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
Ordered 10/27/2010
Delivered 12/13
2003 Mustang SVT Cobra, black convertible. - 6/2007
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
Link: Differential Cover Spreadsheet
Link: Fuel Mileage Spreadsheet
Link: Rapid-Heat Sup Cab Heater Test Graphs
doczenith1 is offline
Old 08-09-2006, 02:27 PM   #17 (permalink)
NCHornet's Avatar
Jack is right. 12 years ago when living on the mountain I used a set of Bosch fog lights, they also said that no more than 16" off the ground was ideal. I had them wired seperatley and would many times just have the headlights off all together. Boy am I glad I don't have to drive thru that anymore, but it was beautiful up there.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 08-09-2006, 03:25 PM   #18 (permalink)
My Photos: (5)
Most of the lights sold as fog lights do not meet this criteria, even some of the well known brands like Hella.
I agree. I have the Hella 500 "fog Lights" and driving lights. I use them mainly off-road. They are more of a "wide light" than a fog light. They work great for what I need, but I wouldn't expect them to be a top of the line true fog light.
2002 Super Duty CC Lariat 4x4 4.5" Donahoe Racing lift
HoustonPSD is offline
Old 08-14-2006, 08:00 PM   #19 (permalink)
stacyl12's Avatar
My Photos: (5)
SteveIn29,
I did not mean to offend you by repeating your post, but I thought that it was important to distinguish between day and night driving. It is perfectly legal to use them during daytime driving when there is fog, or in low light situations (dusk/dawn).
Semper Fi.....
2002 F250 Lariat, CC/SWB, 4x4, 7.3 PSD, Auto, tymar intake, muffler delete, Edge Juice w/Attitude.
stacyl12 is offline
Old 08-15-2006, 04:06 AM   #20 (permalink)
SteveIn29,
Semper Fi.....
[/ QUOTE ]Maybe in GA but in CA the law states...headlights will be on 1 hour before sunset and 1 hour after sunrise. It also says that driving with just parking lights is illegal and doesn't mention that fogs negate that, although I believe when actually driving in fog they might make an exception.
This is what I remember from my driving test so I could be mistaken as it's been a few years.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
Old 08-15-2006, 12:02 PM   #21 (permalink)
can anyone direct me to a schematic on how i might wire the fog lights to activate w/o having to run the head lights as well [img]/ubbthreads/images/graemlins/shrug.gif[/img] in other words i want to be able to have control of them as a separate system........does that make sense to you guys [img]/ubbthreads/images/graemlins/confused.gif[/img]
by the way its on an 01 Excursion v-10 and the fogs activate when you pull out the light switch
OK, it's been a while since I did this..On my 2001PSD, I removed the light/fog light knob and pulled the panel out..need to be carefully, if I remember you'll need to use a small screw driver to "push" the clip back to facilitate removal..once you have the panel in your hand, disconnect the plug-in wiring..Now, here's where it gets a little fuzzy..If you notice, there is a rotating cam that prevents you from pulling the knob out while in the Fog Light position..You'll need to file that off so that the knob can be pulled out..The actuator is held on by small plastic studs that hold it in place..to secure they looked like they had been melted a little to secure..so, I carefully ground on them a little to be able to remove the actuator..and when I put it back together, I used a soldering iron to re-melt the studs..
If you decide to do this..once you get the light/fog light control panel out it will make more sense to you..
Good luck..hope this helps ya
On edit: If your light control panel was/is like my 2001..you'll have to use the small blade screw driver on the Knob..look in the back of it and you'll see a small opening..there's a clip in there that will need to be released..pushed in, so that you can get the knob off.
wingfoot is offline
Old 08-15-2006, 04:52 PM   #22 (permalink)
Supporting Member
My Photos: (24)
My 2001 is also like wingfoot stated. You also have to jump 2 wires together at the switch to get power to the fog light relay when you pull out the switch in any position.
2001 F-250 (pcm PMT2) ISS Pro EV tranny, boost, pyro gauges. TS Performance flip chip. Banks MONSTER exhaust, Maghytec rear diff cover, ITP H/X kit, Whelan 52" Strobe Bar, Fisher 8.5' Snow Plow, 3 Weatherguard tool boxes. HUTCH fuel tank mods, REMANFACTURED Ford transmission.
CPSS is offline
