Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 11-08-2006, 06:37 PM   #1 (permalink)
Fog lights
or should I say lack of them. I had fog lights when I bought the truck back in june, but sometime in the last month or so they have quit working. I have checked the fuse and changed the bulbs but still nothing, is there a relay or something for them somewhere. Thanks
P.S. Those bulbs are a pain to change. [img]/ubbthreads/images/graemlins/mad.gif[/img]
2004 F350 PSD 2wd CC Dually Hypertek stage III
FFretPowerstroke is offline
Old 11-08-2006, 06:42 PM   #2 (permalink)
Re: Fog lights
Make sure the rig is running/key in far forward position when you check your fog lights.
cougarmania96 is offline
Old 11-08-2006, 06:50 PM   #3 (permalink)
Re: Fog lights
I did that was running with both headlights and then just running lights too. still no fog lights.
Old 11-08-2006, 07:27 PM   #4 (permalink)
Re: Fog lights
make sure your high beams are not on, fog lights will not come on with the high beams.
COOK is offline
Old 11-08-2006, 07:33 PM   #5 (permalink)
Re: Fog lights
did that also
Old 11-08-2006, 08:09 PM   #6 (permalink)
My Photos: (38)
Re: Fog lights
Have you had any major service done recently that would necessitate cab removal? There is a connector near the steering gear on the top side of the frame that powers the fog lamps that is easy to miss during reassembly...
The vehicles:
2000 Pontiac Sunfire (absolutely no extras)
1997 Ford Explod ..err.. Explorer (without the Firestone Rollover option)
1965 Ford Mustang (daily commuter until original owner's death)
1998 Trek 4300 (with upgraded brakes and Manitou Black fork)
The man:
Certified Trans Daddy
Master Certified Diesel *****
GregH is offline
Old 11-08-2006, 08:26 PM   #7 (permalink)
Re: Fog lights
nope just reg. pm stuff by me
Old 11-08-2006, 08:32 PM   #8 (permalink)
gibster's Avatar
Re: Fog lights
Is the headlight switch pulled out? seems simple but had a friend who didn't know.
(Built in feb of 03} True blue 2003 f-250,4x4,crew cab, short bed, 6.0,Auto, lariat, fx4, camper package, 4" lift, magnum force air intake, 42,000 miles
gibster is offline
Old 11-08-2006, 10:36 PM   #9 (permalink)
Re: Fog lights
pulled out still no light
Old 11-08-2006, 11:28 PM   #10 (permalink)
RatherBNtheWoods's Avatar
Re: Fog lights
Sorta hate to chime in here with only a little info, but. I believe there is a relay. The relay is what turns them on/off when you go to high beams. I helped a friend some time back fix his, but my head is a blank right now. This sometimers disease is very much bad. But I think I thought, that the relay was a normally closed(on) and opened when the high beams came on. That wouldn't seem to fit your symptoms, unless the contacts were burnt. Not likely. Have you measured the voltage at the bulb with them on? You may should be looking for a ground problem instead of a power problem. Just a thought to narrow it down a little.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 100gal aux fuel tank. A real pig from a stop, but give me 10' and she'll lite'em up.
RatherBNtheWoods is offline
Old 11-10-2006, 10:41 PM   #11 (permalink)
Re: Fog lights
I have no voltage at all at the plug the goes into the light. ?????
Is there any relays for these lights? I tried tracing the wire back from the the lights but with all the room under the hood I could not keep up with them. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
