"Ford" alarm system - Diesel Forum - TheDieselStop.com
Old 08-03-2006, 01:06 AM   #1 (permalink)
"Ford" alarm system
I had a Ford 400K system in my '96 F250 and NEVER had a problem. I understand Ford has used a different source for their current alarm. (used to be Code Alarm) Any reviews on the current system?
Main reasons for using this and not aftermarket are I can arm the system with the elect door lock switch in the arm rest and I can arm/disarm with the keypad. Not to mention it will be installed by a "Ford certified" vendor.
Thanks a lot!
Patrick
...A "Faceplant" is my most consistant wakeboarding "move"
'06 F-350 4X SRW LB Crew Lariat to pull an '04 Malibu VLX and a 10k dump trailer.
Make Welfare as hard to get as a Building Permit....
http://photos.thedieselstop.com/show...hp?photo=32801
Faceplant409 is offline
Old 08-08-2006, 08:36 AM   #2 (permalink)
Re: "Ford" alarm system
The old Code Alarm systems Ford used were just aftermarket alarms installed at the dealer. The new systems are integrated into the truck and as far as I know can't be added after the fact.
It's not really much of an alarm. I would just call it keyless entry.
BTW, a "Ford Certified Vendor" means nothing. The dealer just uses the cheapest local car alarm dealer to install an aftermarket system if the truck didn't come with an alarm.
2004 6.0 PSD CC Lariat FX4, Bulletproof Diesel EGR Cooler upgrade, Scangauge II, High Idle Mod, Tow Package, Air Lift Bags, 2006 Jayco Eagle 325BHS 5th Wheel
KokDiezel is offline
Old 08-08-2006, 10:41 AM   #3 (permalink)
cmirabile's Avatar
My Photos: (9)
I don't remember where I saw it, but some site advertized a "factory' alarm for this truck. It plugged in to the VSM an that was it. Of corse it didn't have shock sensors and a siren unless you added it.
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
AVIC-Z2 In-Dash Navigation System
205cc Elite Sticks
Coolant Filter
Elite Regulated Return Fuel System
FS2500 Oil Filter
HPOP STC Replaced
My Pictures
cmirabile is offline
Old 08-09-2006, 12:36 AM   #4 (permalink)
WAMPAKU's Avatar
My Photos: (14)
code still is the manufacturer for ford alarms. i do the alarms at a dealership. its just a basic alarm that does not plug into anything. the shock sensor is built into the brain. this unit is for keyless entry upgrade or keyless entry. i have my opinions about alarms so pick your poison. the thing about getting a ford alarm is if its a new car its warranty is just the same as the car. after that parts is lifetime but you willhave to cough up for labor.
99.5 F350XLT CC LB 4X4, 8" SUPERLIFT, 17X10 WELD SANDSTORMS, 40/13.50X17 GOODYAER MT/R, AIR INTAKE HEATER PLUG, AFE STAGE II, WHICKED WHEEL,JOHN WOODS TANNY STAGE II, DYNATRAC SUPER DUTY COMBO KIT, AGR ROCK RAM SYSTEM, 6 POSITON CHIP WITH JODY TIPTON BURNS, HOG 4" TURBO BACK EXHAUST, 4.56 GEARS FRONT AND BACK WITH ARB AIR LOCKERS, ARB AIR COMPRESSOR
ECLIPSE 5495, SOUNDSTREAM CONTINUUM, 2 PAIRS ECLIPSE SC8365 3WAY COMPONENTS, ECLIPSE SW9102 SUB. 10" FLIP DOWN SCREEN, PS2, AND LOTS MORE!
truck pics
2002 EXCURSION LIMITED 7.3TDI, AFE STAGE II, DIPRICOL GAUGES, DP TUNER F5 CHIP, 4" HOG PERFORMANCE TURBO BACK EXHAUST
2005 VOLKSWAGON JETTA 1.9TDI, KERMA QLOADER, 100 HP AND 40+MPG IF I AM GOOD.
WAMPAKU is offline
Old 08-15-2006, 01:06 AM   #5 (permalink)
I had one of these installed today and so far I like it a lot. I can arm it with remote, keypad or door lock switch. I can disarm with remote OR pin # on keypad. (pretty cool, I think... I know, I know, "Simple minds...")
Patrick
Old 08-15-2006, 12:25 PM   #6 (permalink)
I installed the Ford alarm with Remote Start. You can use the factory key fob, the alarm key fob, the exterior door keypad, or the interior door lock button. They will all activate the alarm.
Joseph, San Francisco Bay Area
'06 F-350 CC, King Ranch, FX4, 6.0 PSD/TorqShift, Dually, 4.30 Gears, Tow Boss, Loaded, Ford Remote Start/Alarm, No Performance Mods
Proud to be a member:
The Calif. Rifle & Pistol Assoc. (Life Member)
The National Rifle Association
What part of "shall not be infringed" do you NOT understand?
joseph3724 is offline
