Ford recall 09S09 Safety. - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-13-2009, 11:53 AM   #16 (permalink)
Todes's Avatar
Originally Posted by schoolde View Post
This speed control thing, is it only a problem if you use the speed control, or can it be a problem at anytime?
It can happen any time!!!! My uncle's truck caught fire in the middle of the night and set his whole house on fire. Ford bought him a new truck and house, but it can happen any time.
I talked with some guys in our shop, I work at International, and the basics are that it is a sensor that is always on and occasionally brake fluid will leak on to it, shorts and catches the brake fluid on fire and then the whole truck and then what ever may be around the truck. Just got my recall letter for this last week and will be in the shop this weekend.
This is one recall I would not skimp on, yes you may be replacing a fuse down the road......but a HELL of lot better than ohhh lets say a truck! or a house!
As far as the CPS, if your truck isn't randomly shutting down then I wouldn't replace it. Mine was, never fun on the highway, so I took it in when I got the letter and its been about 3months with no issues except for the 1-3mpg that disappered.
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 11-13-2009, 05:02 PM   #17 (permalink)
Does anyone know if this is related to my seemingly temperature/bump related intermittent Speed Control operation.
It doesn't seem to like cold weather, and sometimes a good jolt from the road will kick it off.
REMEMBER:
A Bad Day Fishing is Better than a Good Day Anywhere Else!!!!
2003 F-250 6 Speed.
TightPenny is offline
Old 11-13-2009, 05:15 PM   #18 (permalink)
chuckster57's Avatar
Got my invite today....I don't really trust the dealers in my area, but I guess I will call and play the "it's my only vehicle" card so they will not keep my baby.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 11-13-2009, 09:36 PM   #19 (permalink)
Todes's Avatar
It might be....a quick way to tell is to look at the sensor and see if its covered in brake fluid. If not its somewhere else in the speed control system.
Todes is offline
Old 11-13-2009, 10:27 PM   #20 (permalink)
klhansen's Avatar
My Photos: (169)
Originally Posted by Mark Kovalsky View Post
No, you can have a problem if the battery is connected. It doesn't matter if you use anything on the truck or not, if the truck has power with the key on OR key off it can start a fire.
That's true for gassers, but not for 99-01 diesels (I'm not sure on the 02 and later diesels, because I haven't checked the wiring diagram). On the gassers, the master cylinder mounted cruise cutout switch circuit is hot at all times, but on the 99-01 diesels, it's only hot with key on. I suppose that it might short with the key on and start a fire that grows after you pull into the driveway/garage and shut it off. But that's an unlikely thing, IMO.
A fire going down the road could be pretty disastrous, though.
Hard or no-start? Check Here
klhansen is offline
Old 11-14-2009, 10:57 AM   #21 (permalink)
Does anyone know exactly where this switch is? Pictures? Thanks.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
Old 11-14-2009, 04:38 PM   #22 (permalink)
Mark Kovalsky's Avatar
It's on the brake master cylinder.
Mark
Mark Kovalsky is online now
Old 11-14-2009, 05:51 PM   #23 (permalink)
09s09
Hey Guys, first part of Oct I went down to Ford to check if there was a recall on my 94 Bounder for this exact problem. On a trip back from the lake my unit kept jumpimg in and out of overdrive. They checked my vin # and told me that there was no problem. You guessed it, today I get the recall.
o2824@msn.com is offline
Old 11-14-2009, 07:20 PM   #24 (permalink)
olddieseldude's Avatar
My Photos: (16)
Originally Posted by Todes View Post
...brake fluid will leak on to it, shorts and catches the brake fluid on fire...
I used to think this was the issue too until someone else on the forum stated that brake fluid doesn't burn. I don't know what temperature it would take to burn the fluid, maybe an electrical short is hot enough to make it burn, but it will not burn by applying a flame to it. I tried. It must be the wiring insulation in the wire harness that is burning due to the short.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 11-15-2009, 02:30 AM   #25 (permalink)
boomboom's Avatar
Your right ,when you make an appointment with DMV you go to the front of the line. most of the time The service writer can install the harness that goes in. I'm just saying its that easy to do, I don't want to step on any toes about chain of command.
boomboom is offline
Old 11-15-2009, 09:25 AM   #26 (permalink)
Ya, I'm pretty sure an untrained monkey could put it in as well......and I might actually be OK with that.......if my other option was the service writer I had.
Old 11-16-2009, 07:55 AM   #27 (permalink)
Has anyone experienced a drop in MPG since having the Cam Position Sensor replaced? I am happy with my mileage for once, and do not want this recall to change that.
2002 F 350 4x4 Crew Cab Lariat
7.3 Diesel 6-speed manual
206,000 miles
All Stock, Possible Chip?
schoolde is offline
Old 11-17-2009, 01:58 PM   #28 (permalink)
Todes's Avatar
For anyone still debating the recall for the cruise control......
below is an image(or link, I stink at posting images) of the fix. I just got back from the stealer, 15mins in and out. Looks like they added a harness with two fuses, on at each end. I will do some rerouting later, I don't like how the mechanic did it.
incase the pic didn't come threw here is a link:
GetAttachment.aspx on Flickr - Photo Sharing!
Todes is offline
Old 11-17-2009, 03:18 PM   #29 (permalink)
boomboom's Avatar
I asked them not to install it but just give it to me as a back-up for " just in case ". They did and they got to collect their money from FMC for the recall. I've heard some people have had a drop in MPG and some have not.
boomboom is offline
Old 11-17-2009, 05:35 PM   #30 (permalink)
Domenic's Avatar
I just had both recalls preformed at the local Ford fleet center that my company uses to service our fleet. They completed the recalls in 15 minutes and did not change the cps per my request (wrote it up as having the new replacement). The main Ford dealer indicated that I had no choice in the matter that the new cps would be installed, and the appointment would take three hours. What a difference in customer service between two facilities owned by the same company.
2003 F250 SBSC 4X4 7.3 6spd..Parked and Depreciating!!
2008 Yamaha FJR1300 Daily Driver now.
Domenic is offline
