Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 06-15-2005, 03:17 PM   #1 (permalink)
front brake squeal
Recently replaced my brakes all the way around, new rotors and pads. Ever since I experience a periodic squeal coming from the left front. Last week I removed it to inspect and found that one of the anti-vibration springs had broken. Figuring that this was the problem I purchased a new one from the local ford dealer. After getting it back together the squeal is worse!! My question is has anyone just removed the springs? I have anti-squeal spray on the backs of the pads and I just don't see the reason for the springs that go between the pads. Any ideas???????
2000 f-250 CC 4x4, DP-Tuner 4-pos switch, Dieselsite Extreme CPRx fuel system including Aeromotive fuel pump, Dahl 150 w/ vacuum gauge mounted in cab, NAPA 6637, 4" downpipe and exhaust,isspro EV gauges (pyro, boost and trans temp), CCV mod, tru-cool max trans. cooler, wicked wheel, AIH delete, HX mod, boost relief valve, AC control valve,factory tech valve body, mobil 1 syn ATF, Dieselsite coolant filter set-up
jzeeks is offline
Old 06-15-2005, 08:49 PM   #2 (permalink)
FMTRVT's Avatar
Re: front brake squeal
Honestly, the anti-squeal sprays can cause more problems then they solve.
The V-springs are there to spread the pads away from the rotor to assist in preventing excessive rotor wear, mostly at the high runout areas of the rotors.
Some brake pad formulations just make noise.
Jack
Pics & Instructions:
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 6 Disc Radio Speed Volume Mod . Look Around, Lotsa Stuff
Oil Study Spreadsheets
FMTRVT is offline
Old 06-16-2005, 09:19 AM   #3 (permalink)
POS
Ironically true. Some of the highest quality pads are made so they wear less, but the hardness makes them squeal. There is no quick fix.
<font color="red"> WIX filters at </font><font color="blue">www.fleetfilter.com</font>
POS is offline
