Front Caliper Bolt Size? - Diesel Forum - TheDieselStop.com
Old 01-14-2013, 09:51 AM   #1 (permalink)
kench's Avatar
I've got a sticky caliper (front/drivers).
I'm going to remove it tonight, and lube up the slide pins (hopefully not have to replace caliper).
Can somebody tell me what size bolt holds the front caliper on?
I want to make sure I have the right socket before leaving the shop today.
2001 F-350, 7.3L, Crew Cab, 4x4, Dually.
150,000 miles, and going strong.
It likes to pull a 28' 2005 KZ Frontier Travel Trailer (8,000#).
ISSPRO 3 gauge (pyro, boost, trans) pillar install.
Located on Long Island, NY
kench is offline   Reply With Quote
Old 01-14-2013, 11:36 AM   #2 (permalink)
RT
RT's Avatar
3/4" - Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 01-15-2013, 08:34 AM   #3 (permalink)
kench's Avatar
18mm. Turns out bottom slide pin was siezed. I wish I had time to orderthe guzzle pin slide kit, but I need the truck today.
had to pick up a new caliper bracket and pins.
Not a bad job, but getting the caliper off the rotor without opening the bleeder screw took a lot of time and manuveriing.
Eventually I tried to open the bleeder screw, but it was on so tight I was afraid it would snap off. So I just muscled the caliper off.
