Front leaf springs? - Diesel Forum - TheDieselStop.com
Old 11-13-2009, 02:01 PM   #1 (permalink)
kench's Avatar
Front leaf springs?
So now that I'm looking to get a lift kit, I've been studying every F-350 I see on the road.
I've noticed that all of them (except for a work truck) had coil springs in the front.
My truck has leaf springs all around.
Did it come from the factory like that, or are the front leaf springs after market?
Now I'm wondering if I own an old plow truck!
It's a 2001 F350, cc, drw, PSD 7.3.
2001 F-350, 7.3L, Crew Cab, 4x4, Dually.
150,000 miles, and going strong.
It likes to pull a 28' 2005 KZ Frontier Travel Trailer (8,000#).
ISSPRO 3 gauge (pyro, boost, trans) pillar install.
Located on Long Island, NY
kench is offline
Old 11-13-2009, 02:31 PM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Upto 2004 Leaf springs all 4 corners. 2005 and newer went to coil spring suspension.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
fordsforever73 is online now
Old 11-13-2009, 03:01 PM   #3 (permalink)
aekrogh's Avatar
All 99-03 trucks will have leaf spring fronts on 4x4 models, all 99-03 2wd will have coils in the front. Like fordsforever73 said all 05 and up have coils on all models. Start checking trucks that have the same grill as yours and that will be the same year.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
Old 11-14-2009, 07:59 PM   #4 (permalink)
kench's Avatar
Cool, thanks guys.
kench is offline
